I have a mirror light with single color LED strip in Cold White.
When I add that entity - It will only show as Yellow/Warm White. Is there a way to change this?
In the past it was a simple Sonoff switch (Tasmota), later I change that to Tuya LED strip controller & now it’s a ZigBee LED strip controller - so it’s not related to the device - but to the concept of a light entity.
Examples:
On the right - my Bathroom Yeelight lights that have color temperature control - so it’s exactly how it should be.
Have you ever figured out a solution to this? I also have a single-color light (red) that’s controlled by a switch, and it looks strange in Home Assistant that it shows up as the default yellow color when it’s turned on.
I’ve found CSS-based solutions for settings the color of the light within a single place, like in an entities card, but it’s far from a general solution:
