Is there a way to change the color of the gas consumption bar?
Being color blind, the default color (dark red) is not ideal in dark mode. It’s very hard to see. Is there a way to change this?
With a custom theme, you can set --energy-gas-color to a color of your choice.
I tried that, however I use the dark theme and when setting a single value in a custom theme, HA seems to use the light theme for all other colors. Is there a way for HS to fall back to dark theme for all colors not defined in the custom theme?
Either define different values or delete a line with this var to fallback to a default value.
my_theme:
  light:
    energy-gas-color: ...
  dark:
This (modes) turned out to be doing the trick:
# themes.yaml
custom:
  modes:
    light:
      energy-gas-color: "#4444FF"
    dark:
However, these settings don’t seem to have an effect in the mobile app. In the app, still the original colors are used.
Have you set same theme in the app?
facepalm… haha thanks for reminding me!
