Hello i look for a way to control shelly RGBW over KNX.
On/Off is no problem, but i don´t find a way to change colors.
Can someone help me?
greetings, Wolle
greetings, Wolle
Hi !
You can use knx_event
and get r, g and b values from the raw telegram payload (trigger.event.data.data
is the telegram payload as a list of int 0…255).
Hi Matthias,
do you have a little bit more for me?
KNX_event is clear, but I have no idea how to forward that to shelly.
In Automation i don´t see a way to control colours for shelly rgbw.
greetings, Wolle
The light.turn_on
service should do that - have a look at the service documentation. I have never used rgb myself 🤷
where can i find the service doc?
i found it, now i have to do a look.
OK,
this is a way to control shelly rgbw, but I’m not sure how I’m supposed to manage that all 4 colors (RGBW) from KNX are to be adopted in this automation.
In KNX all 4 colors come as a single group address.
- id: '1671048140828'
alias: Neue Automatisierung
description: ''
- platform: device
type: changed_states
device_id: ca399f7f569aadb1db260270c73197a7
entity_id: switch.shellyplug_s_4022d8890ed1
domain: switch
condition: []
- service: light.turn_on
entity_id: light.shellyrgbw2_d88e91
brightness: 130
rgbw_color:
- 0
- 0
- 255
- 0
your needed data in rgbw_color:
is a list of 4 int 0…255 too, so just use a template to pass the list (or the first 4 items) to that service.
I dont´t understand it.
i have these:
configuration.yaml
knx:
event:
# Philipp RGBW - Rot
- address:
- "1/0/48"
type: "percent"
# Philipp RGBW - Grün
- address:
- "1/0/50"
type: "percent"
# Philipp RGBW - Blau
- address:
- "1/0/52"
type: "percent"
# Philipp RGBW - Weiß
- address:
- "1/0/54"
type: "percent"
automations.yaml
description: ''
- platform: event
event_type: knx_event
event_data:
destination: 1/0/48
brightness: 65
rgbw_color:
- 0
- 0
- 255
- 0
I can’t get any further from this point.
How do I get these 4 values in here now. They are individual values and I don’t understand how to deal with them.
You never said that the colors are spread over multiple GAs 🤷
Maybe you can store the values in a helper attribute or something. Not sure if that works though.
If not you could use individual sensors to store the value.
Hello Matthias,
All colors are always separate in KNX. Each color a percent type group address.
how can i do this and once I have that, what’s next?
I don´t have any idea how to do this.
Thank´s for your help.
Is there anybody who can help me whith this problem?
type: percent
or type: percentU8
(latter is 0-255)light.turn_on
service in the automation action - read documentation about templates on how to do this.OK, now i have the 4 sensors:
- name: "Philipp RGBW - rot"
state_address: "1/0/48"
type: percentU8
- name: "Philipp RGBW - grün"
state_address: "1/0/50"
type: percentU8
- name: "Philipp RGBW - blau"
state_address: "1/0/52"
type: percentU8
- name: "Philipp RGBW - weiß"
state_address: "1/0/54"
type: percentU8
and i have these automation:
alias: Philipp RGBW
description: ''
- platform: event
event_data:
destination: 1/0/48
brightness: 65
rgbw_color:
- 0
- 0
- 255
- 0
the automation works whith the fixed valus for RGBW colors, but i have no idea how to replace the fixed values with the sensor values.
I can´t find something in docs for how to do this. Maybe I’m looking wrong, but I’m treading water.
Could you possibly give me a solution, or at least give a contribution from which one can derive it in a meaningful way?
Use templates to get the states of your sensors.
rgbw_color:
- "{{ states('sensor.rot') | int(0) }}"
Here is documentation for this: https://www.home-assistant.io/docs/configuration/templating/
You also don’t need to use knx_event
as trigger (and define it in configuration.yaml) when you have sensors defined. You can use
automation:
- platform: state
entity_id:
- sensor.rot
- sensor.grün
Here is documentation for this: https://www.home-assistant.io/docs/automation/trigger/#state-trigger
Thank you very much,
the way with templates is new for me.
Here is my complete solution to control Shelly rgbw.
In configuration.yaml
knx:
type: percentU8
type: percentU8
type: percentU8
type: percentU8
In automation.yaml
- id: "1671048140828"
alias: Philipp RGBW
description: ""
- platform: state
entity_id:
- sensor.philipp_rgbw_rot
- sensor.philipp_rgbw_grun
- sensor.philipp_rgbw_blau
- sensor.philipp_rgbw_weiss
brightness: 65
rgbw_color:
- "{{ states('sensor.philipp_rgbw_rot') | int(0) }}"
- "{{ states('sensor.philipp_rgbw_grun') | int(0) }}"
- "{{ states('sensor.philipp_rgbw_blau') | int(0) }}"
- "{{ states('sensor.philipp_rgbw_weiss') | int(0) }}"
Now I need help for the way back.
Do you also have any idea how I send shelly’s status back to the KNX?
First of all, I would have to break down the 4 colors into individual objects again, that’s where the chaos begins for me.
"{{ state_attr('light.shelly...', 'rgb_color')[0] }}"
would get you the red part. [1]
green etc.
Have a look at to play with templates
And to inspect your entities states and attributes.
Thank you, you are the best.
I will try and give feedback.
OK, I also worked with an automation here. Here is my solution Color States from Shelly to KNX.
- id: '1672774943675'
alias: Philipp RGBW Status
description: ''
- platform: state
entity_id:
- light.shellyrgbw2_d88e91
attribute: rgbw_color
- service: knx.send
address: 1/0/49
payload: '{{ state_attr(''light.shellyrgbw2_d88e91'', ''rgbw_color'')[0] }}'
type: percentU8
- service: knx.send
address: 1/0/51
payload: '{{ state_attr(''light.shellyrgbw2_d88e91'', ''rgbw_color'')[1] }}'
type: percentU8
- service: knx.send
address: 1/0/53
payload: '{{ state_attr(''light.shellyrgbw2_d88e91'', ''rgbw_color'')[2] }}'
type: percentU8
- service: knx.send
address: 1/0/55
payload: '{{ state_attr(''light.shellyrgbw2_d88e91'', ''rgbw_color'')[3] }}'
type: percentU8
mode: single
It works fine for me, but is there a way to do it in one “knx.send”?
