I have a automation for lights, It dims when watching movie, turns on backlight of TV etc, BUT when someone moves the sensor triggers full lights, looking into the automation I noticed at the top it says
Test if any of 5 conditions matches
I would want all 5 conditions met, not any of the 5. Is there a way to get all conditions to be met before triggering the lights on full?
You probably could replace those two conditions by a âbelow horizonâ or, even better, in my opinion, use sun angle (usually you have quite good light on external areas when the Sun is higher than -6° from the horizon, even if itâs before sunrise or after sunset - and angle, even if you use a positive one, will adapt better to the different seasons when compared to the 15min).
Is this correct? It wonât allow the automation to run unless you have movimento for more than 2min 30sec. If you have movement for only 2min it wonât workâŚ
I put that in when couldnât find answer and though by delaying the trigger it might help, I have reset it since, Your solution worked and will do sun horizon. Thank you again.
