Is there a way to make cards bigger?
I only need a few things on the tablet which hangs on the way.
See:
Is there a way to make the cards (frontdoor live stream) a bit bigger?
You could set the dashboard as a panel and have all your cards inside a grid card, or even grid cards inside this grid card, with other cards inside.
The default “masonry” dashboard creates cards of same width.
If you need to have one card bigger - your options are:
  1. Use a “sideboard” layout: the “main” card will occupy the largest part of the screen, other cards will be located on the right sidebar (and if you find this sidebar narrow - you can widen it by card-mod theme, goto card-mod thread → 1st post → link at the bottom for a particular code).
  2. Use a “panel” layout, place ONE card of “custom:layout-card” - which will contain all your cards, and then you may specify practically any needed layout (goto dedicated layout-card thread for details).
  3. Same as No2, but with conventional stack cards (vertical-stack, horizontal-stack) + card-mod to define widths of columns (goto card-mod thread as was said above).
Masonry wasn’t available by default. I added manually by downloading the files and putting them in www directory. This worked but someone said it was better to download it via HACS GUI.
If have done that but for some reason the masonry option is not available now. So i am trying to find out why via HACS GUI the masonry option doesn’t appear.
This is a default layout, works out-of-box, no need to download it.
There are 3 standard layouts: masonry (default), sidebar, panel.
Show a screenshot where it is said “masonry option doesn’t appear”.
