Is there a way to set the bottom end of a slider to more than zero?
I have a slider that controls a PWM fan speed. If I go all the way to zero, the fan may not start. I have found that about 15% is the minimum that I can use. Ideally the bottom number would be about 35…
output:
  - platform: ledc
    pin: GPIO27
    # 25KHz is standard PWM PC fan frequency, minimises buzzing
    frequency: "25000 Hz"
    min_power: 15%
    max_power: 100%
Hello. Please format your code.
I did but I used the wrong darn tick.
min_power: 0.15
will limit the output to >15%, but where is the slider coming from?
I assume from this code block. As the name is Fan Speed. It seems to me that ESPHome wants to add the slider since it is a PWM control. I am also trying to figure out how to remove the on/off switch as I am not using a relay and turning it off does not stop the fan and I am ok with that. The noctua fan is so quite at 15% that I do not mind it running at all.
fan:
  - platform: speed
    output: apple_pwm_speed
That wasn’t present on your first post.
What if you post your whole code.
Most of people don’t like to guess here.
This would be the most minimalistic control of pwm with slider limited to min.15%:
number:
    name: "Pwm Fan Slider"
    min_value: 15
    max_value: 100
    step: 1
    optimistic: true
    set_action:
      then:
        - output.set_level:
            level: !lambda "return x/100;"
output:
  - platform: ledc
    pin: GPIO27
    frequency: 25000Hz
Sorry, here is my complete code so far… And yes, I suck at writing yaml, but I am good at hardware.
substitutions:
  friendly_name: Apple Fan Controller
  devicename: apple-fan
  esphome_platform: esp32
  esphome_board: esp32dev
  esphome_project_name: "Apple.temperature_control"
  esphome_project_version: "apple-fan-v.1"
esphome:
  name_add_mac_suffix: false
  project:
    version: $esphome_project_version
  on_boot:
# Power up fan at boot
    priority: 800
    then:
      - if:
          condition:
            api.connected: null
          then:
            - logger.log: API is connected! Now we can trigger what we want!
          else:
            - delay: 1s
            - fan.turn_on: fanpwm
esp32:
  board: esp32dev
  framework:
    type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
  reboot_timeout: 0s
# Allow Over-The-Air updates
ota:
- platform: esphome
wifi:
  domain: .home
  ssid: !secret wifi_ssid
  # Set up a wifi access point
  ap:
    ssid: "${friendly_name}"
    password: !secret wifi_ap_password
dashboard_import:
  package_import_url: github://esphome/example-configs/esphome-web/esp32.yaml@main
  import_full_config: true
web_server:
  include_internal: True
status_led:
  pin:
     number: GPIO2
     inverted: false
i2c:
  sda: GPIO21
  scl: GPIO22
  frequency: 100kHz
output:
  - platform: ledc
    pin: GPIO27
    min_power: 15%
    max_power: 100%
fan:
  - platform: speed
  - platform: sht3xd
    temperature:
      name: "Apple Internal Temperature"
      internal: false
      filters:
        - lambda: return x * (9.0/5.0) + 32.0;
      unit_of_measurement: "°F"
    humidity:
      name: "Apple Internal Humidity"
      internal: false
    address: 0x44
    update_interval: 30s
  # Fan Speed
  - platform: pulse_counter
    pin:
      number: GPIO25
      mode:
        input: true
        pullup: true
    name: PWM Fan RPM
    unit_of_measurement: 'RPM'
    internal: false
    filters:
      - multiply: 0.5
    count_mode:
      rising_edge: INCREMENT
      falling_edge: DISABLE
    update_interval: 3s
switch:
  - platform: restart
Much better.
Replace the fan and output components with the code I posted and try if you like it better.
So, I did and I have a new entry in the front end which is correct. But, I still have the old entry and switch that I do not want.
I wrote, replace the fan and output componets…
You need to delete the fan component on your code
I did, but it would not compile. I had to also remove the command to force it on at boot. So, now it does not start at boot.
substitutions:
esphome:
  project:
  on_boot:
    priority: 800
    then:
      - if:
          condition:
            api.connected: null
          then:
#          else:
#            - delay: 1s
#            - light.turn_on: apple_pwm_speed
esp32:
  board: esp32dev
  framework:
    type: esp-idf
# Enable logging
logger:
api:
  reboot_timeout: 0s
ota:
- platform: esphome
wifi:
  domain: .home
  ap:
dashboard_import:
web_server:
status_led:
  pin:
     number: GPIO2
     inverted: false
i2c:
  sda: GPIO21
  scl: GPIO22
  frequency: 100kHz
output:
  - platform: ledc
    pin: GPIO27
    frequency: 25000Hz
number:
    min_value: 15
    max_value: 100
    step: 1
    optimistic: true
    set_action:
      then:
        - output.set_level:
#fan:
#  - platform: speed
#    name: "Fan speed"
#    output: apple_pwm_speed
#    id: fanpwm
  - platform: sht3xd
    temperature:
      internal: false
      filters:
    humidity:
      internal: false
    address: 0x44
  # Fan Speed
    pin:
      number: GPIO25
      mode:
        input: true
        pullup: true
    name: PWM Fan RPM
    internal: false
    filters:
      - multiply: 0.5
    count_mode:
    update_interval: 3s
switch:
  - platform: restart
It did indeed clean up the panel!
I honestly figured that pointing the on_boot at the ledc would work, it does not. Compile errors. I also tried light.turn_on. It seems that when I take out the fan: section the ability to turn on a boot also goes away. So, what I have been able to figure out is that I have to move the slider just up one point to start the fan after boot. So, it appears something is telling the PWM not to output anything at boot.
INFO ESPHome 2024.12.4
INFO Reading configuration /config/esphome/esphome-web-8281ec.yaml...
Failed config
esphome: None
  name_add_mac_suffix: False
  project:
    version: apple-fan-v.1
  on_boot:
    priority: 800
    then:
      - if:
          condition:
            api.connected: {}
          then:
          else:
            - delay: 1s
              Unable to find action with the name 'ledc.turn_on'.
              ledc.turn_on: apple_pwm_speed
The syntax is:
- output.turn_on: apple_pwm_speed
and if you want to set level:
 - output.set_level:
            level: 0.5 # 50% pwm speed
That was what I was missing… yaml will yet drive me to drinking or kill me.
Works perfectly!
drive you drinking sounds ok, drinking while driving might kill you though…
Nice it worked!
Thanks a bunch, hate to rely on the community. I am learning, but have a long way to go,
We all have… Community is great.
