Is there a way to set the preferred assist pipeline in a service
Based on the availability of the assist agent, I want to switch between the voice assist pipelines. I have an AI Assist agent running on my PC, and one on my server that is always on. So I want to use the one on my PC when its available, otherwise use the one on the server.
I now have set all my assist devices to use the preferred pipeline and I believe the android companion app also uses the preferred one first. If I could change the preferred pipeline in an automation based on the availability, I think that would solve my problem, but any other ideas are welcome as well!.
Bit late but I have had to do this in a script where i can set the chosen pipeline per assist device
Script>Action>device>choose assist device>Change $DEVICENAME$ Assistant option>set to chosen pipeline
I added each device as an action in the script then used this script as an action in an automation that triggers when my primary server is up and another to reverse when server goes down
