Is there a way to use an entity's native controls as the card on dashboard?
When a light group’s entity is selected (Settings>Devices & Services>Entities), I am presented with a popup that allows me turn on or off the light and also control its brightness and color temperature.
I only know of two card options when adding this entity to the dashboard 1) on-off switch, tap to reveal the popup I described above, or 2) lightbulb card, still requires a tap to get to the popup I described above.
Is there away to just use the entity’s popup on the dashboard (using GUI, not YAML)? It is useful and I can directly control the group of lights.
Thanks.
You can use this:
@tom_l – Thank you!!
