I found a DIY wifi one (Well Water Level Meter) that uses webhooks. So I suppose you could change the code to make it work with an IFTTT Webhook and then integrate that with Home Assistant.
It would longer be local like Z-Wave. You could make try to find a Z-wave compatible dev board to do it on (Z-Uno). But I think then that the code wouldn’t be as easy to edit.
