Is there an API to retroactively modify state for a given entity?
I have looked around but I’m not seeing anything “official” so I figured that I’d ask here before attempting to try something hacky…
I have a cloud_polling integration which polls the API for a time-tracking service. This service allows editing of a recorded span while it’s in progress.
As the name/description is the most meaningful aspect, that is what I use for the sensor’s state.
This means that there’s always the chance that the user will change the state of the entity externally in between poll/refreshes which will result in the sensor/entity’s state being recorded “incorrectly” in HA.
Example:
  • t0: User clicks button / uses external source to start the timeline. User forgets to apply a description. The ID for this particular event is 1234.
  • t1: HA polls API, gets back id:1234, description: ''
  • t2: User realizes their mistake, changes description to someExampleString
  • t3: HA polls API again, gets back id:1234, description: someExampleString
  • t4: HA polls API again, gets back id:1234, description: someExampleString
  • t5: HA polls API again, gets back id:1234, description: someExampleString
  • N sample intervals elaps
  • tN: HA polls API again, gets back “No event in progress”
When the user checks with the canonical source of truth / the API that I am polling, they will only see that an event titled someExampleString was happening between t1 and tN.
Since this sensor does not have a unit_of_measurement, the history graph card in HA will show TWO distinct states: between t1 and t2 there will be a color block for the ‘empty’ string and then finally from t3 until tN the history display will show a single block of color for the someExampleString state.
Since the API that I am polling uses the same UUID for the entire event duration, i can detect that the same event is still in progress but the user has changed the description/name of the event.
Is there a way to “backdate” the state of an entity so the recorded history in home assistant matches the canonical source?
Question
Is there a way that I can update the state retroactively? Can I communicate with the recorder platform to change/merge/edit the state(s) for a sensor between some time span? E.G.: “from $now to -700 seconds ago, please eliminate all recorded state changes and just record someExampleString”?
Other alternative
The other alternative is to not use the user-provided description for the actual entity/sensor state and instead record just the UUID for the timeline as the state but put the name/description that belongs to the UUID in the attributes. This would give me the consistent history graph but would be very user unfriendly since they’ll have to consult the entity attributes for the last known name/description and the primary sensor state would just be some UUID.
I’d like to avoid this since it just feels wrong / like an anti-pattern to have sensor.my_cloud_poll_sensor_name with a state of 1234 but an attribute of name: someExampleStringHere instead of the state of someExampleStringHere with an attribute of id: 1234.
