I caught the spelling error in filters but not delay, it looked close enough to be right to me. I appreciate the help, new to this and haven’t gotten the hang of the indentation.
Ok after some fiddling ( the GPIO I wanted to use wouldn’t allow some settings) I got the switch and the binary sensor to upload into my ESP32. There are no errors
So now I should be able to see them in a listing of devices or entities right. I read that they should automagically appear. Do I need to add an integration?
Thanks so much for your help guys
Home Assistant should say it is has discovered the device automatically and ask you to configure it, but if it doesn’t - then yes you can add it by going devices in settings, and then add integration and find ESP Home.
When I try to configure a ESPHome integration it asks for the address of the host. I have put in the local IP and also localhost since it is all part of the same PC I get a message to add the api line to YAML, but it is in there
# Enable Home Assistant API
api:
password: !secret api_password
ota:
Nevermind I am an idiot. I needed to put in the address of the ESP32. It appears to be working now. Now to get more programmed into it and wire up some stuff to it
Each ESPHome device is actually a mini server, and Home Assistant is the client. So rather than the ESPHome devices connecting to Home Assistant, it works the other way around, Home Assistant needs to know the IP address of each device, and will make a connection to each one of them.
Thanks, The lights in the old noggin are starting to come on. A little off subject but is there a info/guide for the gpio pin usage? In the esp home site there is some info , I used pins 1,3,13,26,27 for binary input and used this
The honda door is active and the others are not . Which pins can be used for what purposes. I found two different diagrams for the same board . ESP32-WROOM-32D
