Is there any relatively cheap zigbee hardware with PWM?
Hi, is there any wireless IO like shelly relays, but so it would have transistor output to run Omron Solid state relays?
Would be nice just to able set pvm lenght from 100ms to 1s and then control on/off state just 0-100% value.
Idea it to reduce patio IR -heater power ~40% when sauna is running, as cabling to outhouse is done with 5x2,5mm2 witch (legally) allow max 16A fuses (~11kW) and stove is 6,9kW and IR heaters 6kW, so if all of them are running same time, it blows the fuse and sauna gets cold :smiley:
Its hard to find anything for home and I don’t have money for simatic et200 :smiley:
Zigbee would be optimal as my garden lights are already those (from lidl, havn’t tested yet as I didn’t get my usb - zigbee adapter)
I’ve used ESPhome to write custom firmware for a resistive heater using Slow PWM and Shelly hardware…
I guess you could tack a SSR onto a Shelly for more current drive - some of these load type might offer closer temperature regulation with burst or “standard” PWM.
If this helps, :heart: this post!
