Hi all! I have a need of installing HA with a bunch of the same integrations/addons/hacs-addons over and over again. Is there any way to create pre-configured version of HA, which I would install again and again on different hardware?
How different are we talking here?
Different CPU architectures (arm, x86, etc…)?
Assuming all the hardware had the same x86 CPU architecture you could probably do it with clonezilla.
If in doubt, put everything in a Docker.
Then roughly set up once and save the directory
And then insert the next one
