Is there any way to remove or disable Media Browser?
I do not need this function at this time furthermore, it uses one line in the side menu.
Is there any way to remove this completely???
Thanks!
Long press the title of the side menu.
Hit the cross on the items you want to remove.
Click the 'Done’button at the top of the menu.
I use HA via web browser, and for long press nothing happens…
Let me guess… Safari?
Works in Chrome and Firefox.
The other way is to enable the edit mode via your profile:
Thank you very much!!! It works now!!!
How much I was looking for this… my fault.
Btw, Chrome
Works in Chrome for me.
Where were you long clicking?
Should be here:
You are right again…funny guys at HA :smiley:
This is not my day :smiley:
Sorry, but this is not a solution, rather a workaround.
Hiding the mediabrowser from the sidebar is stored only on the browser / app you do it in, and it isn’t even persisted if you clear your cookies.
I don’t want a mediabrowser, no mather what client connects, because I have no media players connected to home assistant.
Fortunately it was solution enough for the person who asked.
If you want to be able to disable it completely I suggest you go here.
you can remove media_source from your configuration file
You made me curious :slight_smile: :grinning:
In what config file you mean, exactly?
In your configuration.yaml
But if you use default_config you might need to change it
OMG I did not know this function was there, thank you so much!
Is there a way to only allow certain users access to the media browser?
Would like to know too
Would like to know three
HA doesn’t expose a per user or admin/non-admin capability to limit media browser access, which isn’t cool in my situation: multiple members of my household have mobile HA access, and Frigate records baby cam video that is exposed through its media browser integration. The recordings should not be accessible to everyone with a logon, but I am not aware of any method to limit access in 2021.12 … anyone with a user logon has unrestricted access to all media
Same here, everybody with an account ca see all cameras… not normal.
this is really an issue
I use Custom Sidebar V2 to add and/or hide items in sidebar.
I had a similar problem with everybody having access to all the cameras, which is not what I wanted, and I solved it by configuring that in Unifi protect
