I am trying to create a template sensor that evalluates the amount of spare power from our solar panels and uses it to run an electric fire.
The sensor needs to know the amount of power being used by the fire since as soon as the fire is on the ammount of availible power will aparantly reduce by that ammount.
I am trying to save this value as the old sensor output but the sensor will be re-triggered by this change when and will then run before the sensor measuring availible power has had time to reflect the change caused by the fire being on and will thus get the wrong value.
So is there any way to stop the sensor being trigfgered by the change to its own output
I have looked at saving the value in a ‘var’ but think the same problem will occur.
Basically i want the template to run when sensor.elec_import_export changes and not when sensor.elec_export_watts changes
code so far is :-
device_class: power
unit_of_measurement: W
state: >
{% set temp = states('sensor.elec_export_watts') | float(0)}
{% if(states('sensor.elec_import_export') | float(0) + temp <= 0.1) %}
{% set output = 0 %}
{% else %}
{% set output = states('sensor.elec_import_export') | float(0) + OldOutput %}
{% set output = output*1000 %}
{% set output = output | int %}
{% endif %}
{% if(output > 1000) %}
{% set output = 1000 %}
{% endif %}
{{ output }}
