I would like to know how long the wifi connection has been connected?
I have HA ping Google every minute.
# Ping Google to check internet connection
- platform: ping
host: 8.8.8.8
scan_interval: 60
This gives you binary_sensor.internet which you can use in a logbook card, for example.
It is in ESPHome that i need it. In ESPHome binary_sensor.ping is not available.
It is a feature request: https://github.com/esphome/feature-requests/issues/242
Also this is a binary i would like a time…
Do you want to know, when WIFI is connected or do you need to know, if a specific host could be reached.
For the first, you could use Wifi.connected from WIFI Component. Check in intervals and store the timestamp into a global variable. This you can make available to HA.
Ulrich
again, esphome does not have ping. You could write a custom component to ping another host.
But ping doesn’t tell you if the wifi connection is down. A ping failure could be because the ping destination host is down.
This can help you?
I am not clear what you are asking. What Wi-Fi connection are you wanting timed? And, why?
I have some home assistant sensors with on_value automation. When the wifi connection drops and it comes back up the on_value automation is run. Even if the value has not changed.
I was thinking to disable the automation as long as the connection isn’t active for more than 30 seconds…
But i solved it by storing the value as a global. And checking if it changed before starting the automation…
