Is this a bug or am I missing something? [SOLVED]
An automation failed this morning and when I checked the trace, I see why. The action for the door closing is not coded correctly. See below. Running 2022.3.5 on Intel NUC.
alias: Turn on radio when alarm is armed
initial_state: true
  platform: state
  entity_id: alarm_control_panel.home_alarm
  to: armed_away
  - service: script.turn_on
    entity_id: script.radio_alarm
  - service_template: >-
      {% if is_state('light.garage_light_main' , 'on') %} light.turn_off {%
      endif %}
    entity_id: light.garage_light_main
  - service_template: '{% if is_state(''cover.garage'' , ''open'') %} cover.close_cover {% endif %}'
    entity_id: cover.garage
Have a look though at the actual automation. Why is there a difference?
## Turn on radio in rumpus and ensuite when alarm sets ##
  - alias: 'Turn on radio when alarm is armed'
    initial_state: true
        platform: state
        to: 'armed_away'
## script in scripts folder [radio.yaml] ##
      - service_template: "{% if is_state('light.garage_light_main' , 'on')
         %} light.turn_off
         {% endif %}"
      - service_template: "{% if is_state('cover.garage' , 'open')
         {% endif %}"
Both of your templates are missing an else case.
e.g. If the garage light is not on, there is no service available for the service_template and an error occurs and the actions stop. Likewise if the cover is not open.
Also you no longer need to use service_template just service will do.
If you do not have an else case, use the choose action instead of a template.
      - choose:
          - conditions:
              - condition: state
                state: 'on'
            sequence:
              - service: light.turn_off
      - choose:
          - conditions:
              - condition: state
                state: 'open'
            sequence:
              - service: cover.close_cover
Thank you. I was just reading about the deprecated service_template. It so hard to keep up these days! I’ll make some tweaks.
I just updated my comment with the choose example.
That is very much appreciated as that would of taken me about 2hrs!!
You may not need the templates/choose actions. Turning off a light that is already off is no issue. However closing a cover that is already closed may open it if the close and open actions are the same. So maybe this will work:
Or maybe you will need the choose action for the cover. You shouldn’t need it for the light.
Thanks again. Based on your feedback I’m searching out all of my service_templates and looking as to how I can improve those too.
Any chance you could chime in on this issue for me too?
