I will mess with that, thank you.
Turns out, this flow doesn’t work. I must have it programmed wrong. Looking into why that might be now. ACtually, not a single flow I put together works, but I wanted to focus on this one because it’s the simplest one I have.
Maybe someone can point me in the right direction? When it was deployed, it did absolutely nothing. I tried random things, and couldn’t get it. I think I may be using BigTimer wrong, but I’m not seeing it.
[{"id":"df2a34fc.1b1348","type":"tab","label":"Slider open when dark out","disabled":false,"info":"Turn on the backyard flood light when slider is opened after dusk, and before dawn. "},{"id":"c93a7896.149678","type":"server-state-changed","z":"df2a34fc.1b1348","name":"Slider","server":"26956a45.92d866","version":1,"entityidfilter":"binary_sensor.slider_contact","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"off","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":90,"y":220,"wires":[["8f8eb913.1c5378"],["7ba443cc.d9f43c"]]},{"id":"2944f2b8.138d4e","type":"api-call-service","z":"df2a34fc.1b1348","name":"Flood Light On","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_on","entityId":"light.flood","data":"{\"brightness_pct\":100}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":402,"y":167,"wires":[[]]},{"id":"90a7e364.38359","type":"api-call-service","z":"df2a34fc.1b1348","name":"Flood Light Off","server":"26956a45.92d866","version":1,"service_domain":"light","service":"turn_off","entityId":"light.flood","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":423,"y":253,"wires":[[]]},{"id":"8f8eb913.1c5378","type":"bigtimer","z":"df2a34fc.1b1348","outtopic":"","outpayload1":"","outpayload2":"","name":"Dark Out?","comment":"","lat":"27.918981","lon":"-81.866833","starttime":5001,"endtime":"5000","starttime2":0,"endtime2":0,"startoff":0,"endoff":0,"startoff2":0,"endoff2":0,"offs":0,"outtext1":"","outtext2":"","timeout":1440,"sun":true,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"day1":0,"month1":0,"day2":0,"month2":0,"day3":0,"month3":0,"day4":0,"month4":0,"day5":0,"month5":0,"day6":0,"month6":0,"d1":0,"w1":0,"d2":0,"w2":0,"d3":0,"w3":0,"d4":0,"w4":0,"d5":0,"w5":0,"d6":0,"w6":0,"xday1":0,"xmonth1":0,"xday2":0,"xmonth2":0,"xday3":0,"xmonth3":0,"xday4":0,"xmonth4":0,"xday5":0,"xmonth5":0,"xday6":0,"xmonth6":0,"xd1":0,"xw1":0,"xd2":0,"xw2":0,"xd3":0,"xw3":0,"xd4":0,"xw4":0,"xd5":0,"xw5":0,"xd6":0,"xw6":0,"suspend":false,"random":false,"repeat":true,"atstart":false,"odd":false,"even":false,"x":237,"y":180,"wires":[["2944f2b8.138d4e"],[],[]]},{"id":"7ba443cc.d9f43c","type":"stoptimer","z":"df2a34fc.1b1348","duration":"10","units":"Minute","payloadtype":"num","payloadval":"0","name":"","x":248,"y":260,"wires":[["90a7e364.38359"],[]]},{"id":"26956a45.92d866","type":"server","z":"","name":"Home Assistant"}]
