I installed https://github.com/SNoof85/lovelace-tempometer-gauge-card through HACS but it looks like this
the configuration is
type: 'custom:tempometer-gauge-card'
entity: sensor.climate_dht11_temperature
entity_max: sensor.temp_high # These are template sensors which just show an input_number + or - 3°
entity_min: sensor.temp_low
max: 50
min: 10
style: thermometer
title: Temperature
Alternatively:
What other gauge components with VARIABLE min/max thresholds/severity are there?
Basically, I want to set a target temperature through an input_number and the gauge should be green, if the actual temperature is equal to the set temperature ±2, blue if it’s too low and red if it’s too high (perfect would be if I could define two more areas: a little too high +2 to +3 is orange and -2 to -3 is light blue)
I tried to use the built in gauge in combination with https://github.com/iantrich/config-template-card but failed miserably…
