Is this ok?
Hey all - trying to troubleshoot some issues with my zwave network. I recently added the python graph tool and it cam back with this:
Does this look right? I ask because I am seeing little meshing going on (just one battery device) and I keep losing devices on the network after a few days. I see some devices with pretty high RTT that have plenty of other devices to mesh through but it wants to go direct…
I have done plenty of heals etc but nothing seems to change the mesh. Be interested in people thoughts.
Thanks.
What tool is this?
That’s fine - it says that your controller can be reached by almost everything, which is ideal.
You’ll also find that the meshing tool simplifies the mesh significantly. There are many other links it doesn’t show, between those yellow nodes.
Thanks Tinkerer. Do you have any tips on what else I can be checking as to why I keep losing connectivity to devices on my network and require a power cycle at the breakers every few days?
More detail in this thread: Aeotec devices with wrong names and other issues
You’ve either got interference, or other connectivity issues. Meshing the graph might help with identifying the second.
Ok great thanks. How do I ‘mesh the graph’? Is that an option of the python graph?
Just one thing to add, one of these devices has now stopped working - node 54. However, when I do a heal on the network, the node seems to be responding just fine and quickly:
2018-10-07 10:10:57.658 Detail, Requesting routing info (neighbor list) for Node 54
2018-10-07 10:10:57.658 Detail, Node054, Queuing (Command) Get Routing Info (Node=54): 0x01, 0x07, 0x00, 0x80, 0x36, 0x00, 0x00, 0x03, 0x4d
2018-10-07 10:10:57.658 Detail, Notification: ControllerCommand - Completed
2018-10-07 10:10:57.658 Info, Node054, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=54): 0x01, 0x07, 0x00, 0x80, 0x36, 0x00, 0x00, 0x03, 0x4d
2018-10-07 10:10:57.663 Detail, Node054, Received: 0x01, 0x20, 0x01, 0x80, 0x01, 0x00, 0x14, 0x00, 0x00, 0xe8, 0x81, 0x15, 0x37, 0x12, 0x0f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1d
2018-10-07 10:10:57.664 Info, Node054, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2018-10-07 10:10:57.664 Info, Node054, Neighbors of this node are:
2018-10-07 10:10:57.664 Info, Node054, Node 1
2018-10-07 10:10:57.664 Info, Node054, Node 19
2018-10-07 10:10:57.664 Info, Node054, Node 21
2018-10-07 10:10:57.664 Info, Node054, Node 44
2018-10-07 10:10:57.664 Info, Node054, Node 46
2018-10-07 10:10:57.664 Info, Node054, Node 47
2018-10-07 10:10:57.664 Info, Node054, Node 48
2018-10-07 10:10:57.664 Info, Node054, Node 49
2018-10-07 10:10:57.664 Info, Node054, Node 56
2018-10-07 10:10:57.664 Info, Node054, Node 57
2018-10-07 10:10:57.664 Info, Node054, Node 59
2018-10-07 10:10:57.664 Info, Node054, Node 61
2018-10-07 10:10:57.664 Info, Node054, Node 65
2018-10-07 10:10:57.664 Info, Node054, Node 66
2018-10-07 10:10:57.664 Info, Node054, Node 67
2018-10-07 10:10:57.664 Info, Node054, Node 69
2018-10-07 10:10:57.664 Info, Node054, Node 70
2018-10-07 10:10:57.664 Info, Node054, Node 74
2018-10-07 10:10:57.664 Info, Node054, Node 77
2018-10-07 10:10:57.664 Info, Node054, Node 81
2018-10-07 10:10:57.664 Info, Node054, Node 82
2018-10-07 10:10:57.664 Info, Node054, Node 83
2018-10-07 10:10:57.664 Info, Node054, Node 84
2018-10-07 10:10:57.664 Detail, Expected reply was received
2018-10-07 10:10:57.664 Detail, Message transaction complete
2018-10-07 10:10:57.664 Detail, Node054, Removing current message
If it was connectivity issues, would I see it here? As mentioned before, everything works perfectly (like really fast) for a day or so after powecycling through the breakers, so it’s weird that it degrades over time or is that just how zwave works? Looking at the logs, I do not see much traffic at all, so it doesn’t seem to be getting congested. Or am I just not seeing all the logs and I need to up the level of logging?
Any advice truly appreciated.
Thanks.
Have a look at the pinned messages in the Z-Wave section of the forum - there’s a couple of options there.
