I don’t know if I’m describing it correctly…
The idea is to be able to show the values from 2 different sensors in 1 card.
Of course, I could put them in the same view.
The reason is: I want to keep that card size just big enough for 1 value.
Also, the 2nd value is less important but sometimes I want to be able to check it.
I guess it could be done with a 2 conditional cards but I wonder if this is possible with just 1 card.
Any help/idea is highly appreciated!
EDIT: for clarification
I want to be able to see the value from 2 different temp sensors.
By tapping on the card, it should switch from the temp from sensor 1 to the one of sensor 2.
Tapping again would switch to temp 1 again.
