Is this possible? “Adaptive automation”
Hi everyone,
I’m looking for an “adaptive” automation:
I have a button with only 2 actions:
  • click
  • hold
I want following automation:
  • click: toggle light
  • hold: increase brightness
  • release + hold within 1sec: decrease brightness
  • release + hold within 1 sec: increase colortemp
  • release + hold within 1 sec: decrease colortemp
  • etc …
So the trick is that the “hold” action depends on the previous action and the fact that the “hold” action is triggered within one second after a “click” or another “hold”
I think I need some helpers:
  • a timer to detect the “1 second”
  • a toggle that defines the active action
Is this possible?
Can somebody provide me with a sample code?
Thanx!
Bart
Example of detecting a Hue dimmer switch’s ‘long_release’ event immediately after an ‘initial_press’ event.
The automation listens for ‘initial_press’ event then uses a wait_for_trigger to listen for a 'long_release` event (but it doesn’t wait for longer than 2 seconds).
alias: example
  - platform: event
    event_type: hue_event
    event_data:
      type: 'initial_press'
      subtype: 4
condition: []
  - wait_for_trigger:
      - platform: event
        event_data:
          id: '{{ trigger.event.data.id }}'
          type: 'long_release'
          subtype: 4
    timeout: '00:00:02'
    continue_on_timeout: false
  - service: script.turn_on
      entity_id: script.whatever
hi @123 ,
thanx for this sample!
But…
the script will be triggerd if you have a long_release within 2 secs after a initial_press, right?
what I want to achieve is
  • immediate action on “long press” (brightness up)
  • and the kind of action will change if this “long press” is initiated within a period of 1 second after another action (brightness down, colortemp up/down, hue up/down, …)
In fact I want to imitate the default behavior of a single butoon you can find in a lot of meeting rooms, f and where you can toggle light and dim up/down with only two actions: click and hold
What you want is achievable using the techniques employed in the example I provided.
