trying to create a card with set of multiple-entity-row 's I a trying to pass along a templated entity_id from the main switch, and template the power sensors as primary and secondary info per line. as I created a config with a decluttering card, (with which we can not template as such) I need a config per line for each switch/sensors combination.
Would love to explore the possibility for templating though, and maybe this is possible with the Lovelace_gen? Or card_templater.
this is what it would ideally look like:
type: custom:auto-entities
card:
type: entities
title: Multiple entities
show_header_toggle: false
filter:
include:
- entity_id: switch.sw*_template
options:
type: custom:multiple-entity-row
state_color: true
toggle: true
secondary_info: last-changed
primary:
entity: sensor.{{entity.entity_id[10:-9]}}_actueel
unit: Watt
secondary:
entity: sensor.{{entity.entity_id[10:-9]}}_totaal
unit: kWh
sort:
method: name
hope this is self explanatory, and of course it doesn’t work, but it shows what I need.
loooking like this:
made with decluttering:
card:
entity: switch.sw_[[entity]]_template
state_color: true
toggle: true
primary:
entity: sensor.[[entity]]_actueel
unit: Watt
secondary:
entity: sensor.[[entity]]_totaal
unit: kWh
and card config:
type: entities
title: Switches multiple entity
entities:
- type: custom:decluttering-card
template: switches_multiple_entity
variables:
- entity: 'espresso_keuken'
variables:
- entity: 'multi_purpose'
variables:
- entity: 'vaatwasser_keuken'
the switches all have the entity_id’s like:
switch.sw_boiler_bijkeuken_template
and the sensors:
sensor.boiler_bijkeuken_state
sensor.boiler_bijkeuken_totaal
would you please have a look if I can realize this, in 1 config with custom-cards?
thanks!
