using the workday binary_sensor to select action in an automation, would this be correct? only have the 11 and 11:30 triggers lead to action on work days?
- alias: Turn off morning switches at 11
id: Turn off morning switches at 11
- platform: time
at: '11:00'
- platform: time
at: '11:30'
- platform: time
at: '12:00'
condition:
{{states('input_select.activity') not in ['Slapen','Gym']}}
{{trigger.to_state.state not in ['11:00','11:30'] or
is_state('binary_sensor.workday_sensor','on')}}
Secondly, I cant seem to find why the workday binary sensors creates a binary_sensor.workday_sensor, instead of binary_sensor.workday, which would suffice. The suffix _sensor really is redundant?
thanks, but I am not sure that would be necessary? to elaborate: I had it functioning with the 3 triggers, and the first condition only.
It triggers every day on the given times, checks the activity condition , and performs the action.
Today I only wanted to add the 2nd condition, that it shouldn’t act on the 2 times when not a workday.
I was merely insecure whether the trigger.to_state.state was the correct trigger for checking these times?
Coming to think of it, I could of course also use the sensor.time for that
{{states('sensor.time') not in ['11:00','11:30']}}
You are right, did miss this shorthand syntax so far. I suspect the state of the Time Trigger is different from the format to specificy. So, triggering at ‘11:00’ could result in trigger.to_state.state being someting like ‘11:00:00’.
Maybe use traditional syntax here:
condition:
- "{{states('input_select.activity') not in ['Slapen','Gym']}}"
- condition: OR
conditions:
- condition: time
after: '11:30:00'
- condition: state
entity_id: binary_sensor.workday_sensor
state: "on"
The sensor’s name is computed from the “name” attribute and by default that name is “Workday Sensor”. Add a custom “name” to override this.
condition:
{{states('sensor.time') not in ['11:00','11:30'] or
to work, the trigger.to_state.state version doesnt.
yeah thanks, I could do that indeed, forgot about that.
Or create a PR
-edit_
these work too:
{{as_timestamp(trigger.now)|timestamp_custom('%H:%M')}}
# or
{{trigger.now.strftime('%H:%M')}}
