Any links to A10?
@tylas13 can you confirm that you have the following folders in your main edl folder?
Hi @staceydodds thanks, I just checked and confirmed I have all Library files.
Doing a bit more poking with Warp it looks like it doesnāt like that capstone reports at x86_64 even though it should be built to use all 5 architectures.
file /opt/miniconda3/lib/python3.12/site-packages/capstone/lib/libcapstone.dylib
/opt/miniconda3/lib/python3.12/site-packages/capstone/lib/libcapstone.dylib: Mach-O 64-bit dynamically linked shared library x86_64
I am not positive if this is a false positive and there isnāt another setting I am missing though.
Hi @tylas13 unfortunately you are in foreign territory for me. I have an M1 MacBook Pro, but at home I am using my older Touch Bar i9 MacBook Pro so itās intel based. Iāve not had to do this on the newer ARM architecture.
That must be the issue then, getting the environment ready on ARM is difficult at best. If I figure it out Iāll post a work through on this feed, but I may just go to a friendās house and work it up through Linux. Thanks everyone for the help.
system-quack-arm-aonly-gapps.img.xz
It must be flashed via fastboot. First flash a stock package that allows u to unlock the bootloader the unlock it from fastboot. Then flash the android 11 package then flash the image from fastboot then relock the bootloader
^copied verbatim from the discord channel, I havenāt verified it it works
I made a couple videos for folks who may want to use the Thinksmart with my View Assist project. The videos are far from polished but may help some who have never flashed a device. Sharing here if there is interest:
Note in the first video I downloaded/extracted the wrong ROM. I corrected the link in the description and discuss that correction in the beginning of the second video
Can you use any voice assistant - Iāve been playing with the Open AI extended project and itās promising although does give incorrect t info at times.
Iām trying to get to a point where I can unlock the bootloader using fastboot but no matter what ROM I flash, it doesnāt allow me to unlock. What do I need to actually do to enable fastboot to unlock?
Iām using fastboot oem unlock-go
gives an oem unlock is not allowed error
Thanks.
This works with Assist so if you are tied in there you should be good. The project supports both satellites with video and audio only. Still working through documenting and these videos are part of that.
OK thanks - Iām still stuck on this device with freezing on the boot logo, no matter what Iāve done and installed various images first and then the A11. Iām totally at a loss now. I had another device install OK but this one isnāt playing ball.
Is there a solution to the A11 crash to Lenovo screen on boot when wifi is enabled? Maybe I should write an automate/tasker type routine to disable wifi on start up and wait ten or so seconds and enable? Just not sure it would be fast enough to work unless thereās a way to set wifi always off on boot in the settings?
THIS is probably the last remaining thing on the list to fix for the device to be close to perfect.
I recall that @FelixKa found it to be a driver issue with the later gsi firmware(s) and @Endlessvoid mentioned to try with Android 10.
Not sure if the thinksmart fixes that @deadman96385 applied to the a11 gsi have been backported to a10.
Thanks for the info. I think Iām in too deep with A11 to try anything new at this time.
I was going to try A10 but this bloody device just wonāt boot.
Flash one of the roms in @deadman96385ās xda thread.
They are complete dumps. Kingston-ha-rom is not.
Iāve done that about 8 times now - all kinds of images from the debug and through the various versions. Something odd is going on.
Is the bootloader still unlocked? If so, it wonāt boot anything.
There are two conditions enforced on boot:
- That the boot image is signed⦠with any key
- That the bootloader is in a locked state
Yeah, the conditions are kinda self defeating, but thatās the security theatre that Lenovo gave us ![]()
Itās locked.
I was trying to unlock it to follow some instructions to install A10 the other day and nothing I did was able to unlock it.
I was doing this from fastboot. It saw the device and said it was already locked when I used the lock command and said it was unable to unlock when I tried to unlock it. What is it specifically that allows unlocking? I also tried this with multiple different ROMs flashed
Hey pgale - wanted to let you know I ran into the same issue today. Running macOS on a M1 air. Flashed multiple times/Images and still got stuck on the HA screen. I ended up trying a few different USB C to USB A adapters, and finally one flash worked. I was able to successfully flash with a different adapter following the guide.
