Is touchlink via zigbee2mqtt on Home Assistant Yellow possible without any external adapters?
After having received my Home Assistant Yellow if been trying to migrate my Hue devices (bulbs, light strip) to the internal Yellow Zigbee adapter.
Since it concerns Hue I need to factory reset those device using the touchlink command (if I’m not mistaken). I’m trying to do this via the instructions here. However, I keep getting the following errors:
Debug 2022-11-26 13:06:29Received MQTT message on 'zigbee2mqtt/bridge/request/touchlink/factory_reset' with data ''
Info 2022-11-26 13:06:29Start Touchlink factory reset of first found device
Error 2022-11-26 13:06:40Failed to factory reset device through Touchlink
Error 2022-11-26 13:06:41Request 'zigbee2mqtt/bridge/request/touchlink/factory_reset' failed with error: 'Failed to factory reset device through Touchlink'
Debug 2022-11-26 13:06:41Error: Failed to factory reset device through Touchlink at Bridge.touchlinkFactoryReset (/app/lib/extension/bridge.ts:380:19) at Bridge.onMQTTMessage (/app/lib/extension/bridge.ts:123:34)
Info 2022-11-26 13:06:41MQTT publish: topic 'zigbee2mqtt/bridge/response/touchlink/factory_reset', payload '{"data":{},"error":"Failed to factory reset device through Touchlink","status":"error"}'
I can’t find any help on these errors and therefore I have a simple question: is touchlink via zigbee2mqtt on Home Assistant Yellow possible without any external adapters?
My guess is the functionality hasn’t been added to z2m’s ezsp support.
Probably best to post a query at https://github.com/Koenkk/zigbee-herdsman/issues/319.
There are five ways to reset a hue bulb, see Philips 433714 control via MQTT | Zigbee2MQTT
