everthing Tuya related just stopped worked. I am running hassio on a raspberry pi3. it still works through the app but HA is showing everything as entity not found.
found this in the logs:
Thu Mar 07 2019 06:34:05 GMT-0500 (Eastern Standard Time)
Error during setup of component tuya
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 159, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw)
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 57, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/local/lib/python3.7/socket.py", line 748, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 343, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 839, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 301, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 168, in _new_conn
self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7301b3b0>: Failed to establish a new connection: [Errno -3] Try again
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 398, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='px1.tuyaus.com', port=443): Max retries exceeded with url: /homeassistant/auth.do (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7301b3b0>: Failed to establish a new connection: [Errno -3] Try again'))
File "/usr/local/lib/python3.7/site-packages/homeassistant/setup.py", line 154, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/tuya/__init__.py", line 60, in setup
tuya.init(username, password, country_code, platform)
File "/usr/local/lib/python3.7/site-packages/tuyapy/tuyaapi.py", line 44, in init
self.get_access_token()
File "/usr/local/lib/python3.7/site-packages/tuyapy/tuyaapi.py", line 59, in get_access_token
'from': 'tuya'
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 116, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='px1.tuyaus.com', port=443): Max retries exceeded with url: /homeassistant/auth.do (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7301b3b0>: Failed to establish a new connection: [Errno -3] Try again'))
