Just switched over the Hassio and was wondering if there has been a 59.1 version released as yet? Or am I missing something with their update procedures?
Hassio always lags by a few days. We didn’t get 59.0 at all (or 58.0 either actually) Just need to be patient
Lol
… and it’s available! Hassio 0.59.1.
Yep! Just updated and as suspected we skipped 59.0 as well.
Why on earth would they release a older version?
Update failed, only me?
17-12-05 09:28:18 INFO (SyncWorker_15) [hassio.dock.interface] Update docker 0.58.1 with homeassistant/raspberrypi3-homeassistant:0.59.1
17-12-05 09:28:18 INFO (SyncWorker_15) [hassio.dock.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.59.1.
17-12-05 09:28:32 ERROR (SyncWorker_15) [hassio.dock.interface] Can't install homeassistant/raspberrypi3-homeassistant:0.59.1 -> 404 Client Error: Not Found ("no such image: homeassistant/raspberrypi3-homeassistant:0.59.1: No such image: homeassistant/raspberrypi3-homeassistant:0.59.1").
I don’t have it…
Me not???
Really…No sign of it here either !!
Ah ok guys, just me then!
Can I take a snapshot, copy it from the backup folder, re-write the SD card and just put the snapshot back in the backup folder and perform a restore?
hassio homeassistant update
Error on homeassistant/update: Version 0.58.1 is already in use
Not sure how often hassio checks for updates, but you can go to http://hassio.local:8123/hassio/advanced and click Reload
under the Supervisor section. That will force it to check for updates. Once it’s done reloading, Home Assistant should show there is an update.
Why wouldn’t they have released 59.0 after Hassbian 59.0? At least it was a short wait for 59.1 anyway.
