Islamic Prayer Times Failed to set up
Log Details (ERROR)
Logger: homeassistant.config_entries
Source: components/islamic_prayer_times/__init__.py:68
First occurred: 10:22:54 (1 occurrences)
Last logged: 10:22:54
Error setting up entry Islamic Prayer Times for islamic_prayer_times
  File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 449, in _make_request
    six.raise_from(e, None)
  File "<string>", line 3, in raise_from
  File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 444, in _make_request
    httplib_response = conn.getresponse()
  File "/usr/local/lib/python3.10/http/client.py", line 1374, in getresponse
    response.begin()
  File "/usr/local/lib/python3.10/http/client.py", line 318, in begin
    version, status, reason = self._read_status()
  File "/usr/local/lib/python3.10/http/client.py", line 279, in _read_status
    line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
  File "/usr/local/lib/python3.10/socket.py", line 705, in readinto
    return self._sock.recv_into(b)
TimeoutError: timed out
  File "/usr/local/lib/python3.10/site-packages/requests/adapters.py", line 489, in send
    resp = conn.urlopen(
  File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 787, in urlopen
    retries = retries.increment(
  File "/usr/local/lib/python3.10/site-packages/urllib3/util/retry.py", line 550, in increment
    raise six.reraise(type(error), error, _stacktrace)
  File "/usr/local/lib/python3.10/site-packages/urllib3/packages/six.py", line 770, in reraise
    raise value
  File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 703, in urlopen
    httplib_response = self._make_request(
  File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 451, in _make_request
    self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
  File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 340, in _raise_timeout
    raise ReadTimeoutError(
urllib3.exceptions.ReadTimeoutError: HTTPConnectionPool(host='api.aladhan.com', port=80): Read timed out. (read timeout=10)
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 357, in async_setup
    result = await component.async_setup_entry(hass, self)
  File "/usr/src/homeassistant/homeassistant/components/islamic_prayer_times/__init__.py", line 30, in async_setup_entry
    await client.async_setup()
  File "/usr/src/homeassistant/homeassistant/components/islamic_prayer_times/__init__.py", line 149, in async_setup
    await self.hass.async_add_executor_job(self.get_new_prayer_times)
  File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
  File "/usr/src/homeassistant/homeassistant/components/islamic_prayer_times/__init__.py", line 68, in get_new_prayer_times
    return calc.fetch_prayer_times()
  File "/usr/local/lib/python3.10/site-packages/prayer_times_calculator/pray_times_calculator.py", line 132, in fetch_prayer_times
    response = requests.get(url, params=params, timeout=10)
  File "/usr/local/lib/python3.10/site-packages/requests/api.py", line 73, in get
    return request("get", url, params=params, **kwargs)
  File "/usr/local/lib/python3.10/site-packages/requests/api.py", line 59, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/local/lib/python3.10/site-packages/requests/sessions.py", line 587, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.10/site-packages/requests/sessions.py", line 701, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.10/site-packages/requests/adapters.py", line 578, in send
    raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPConnectionPool(host='api.aladhan.com', port=80): Read timed out. (read timeout=10)
ANNY HELP
So eloquently put
There was a timeout trying to get information from http://api.aladhan.com so either there was a problem on that server when you tried, or your HA instance has trouble accessing it (networking problems). If you try again, does it work now, and/or could there be anything preventing HA from accessing it (no network connection, firewall, …)
This is the request response when i Curl that api url from my home assistant server
