Sometime during one of the many updates to Home Assistant the Cover integration with iSmartgate started reporting that my garage door was closed when it was open and vice versa. Any way to fix that short of removing and re-adding? thanks.
Not sure the root cause of this issue, but if you want to get rid of it locally, you can create a template cover and reverse your physical device states. This is rather a hack but not a solution
