Recently I have bought myself a new smart samsung washing machine and dryer and integrated them in HA using the SmartThings integration which works perfect so far.
I can add entitty card using sensors:
sensor.dryer_completion_time
sensor.washer_completion_time
And it shows me the remaining time or how long ago it was finished.
Below example shows how long ago the program was completed:
Above example only works when using entity card, when I used the same sensor in any other way it shows me “garbage”, unreadable ISO time. It just isn’t displayed as nice as it was with entity card.
How can i accomplish the same nice remaining/past time information when using these remaining time sensors without using entity card?
I tried playing with templates but i think it can be done more easily. I don’t understand why only entity cards shows it like this and any other card doesn’t?
Hi thanks for your reply.
I tried it in development tools templating but it returned None.
Als when i read the docs it ony provides dates in the past and in my case i would like to know how long it takes for the program to be finished. My example showed only when it was completed but it also shows how long untill it is completed.
Anyway, templating is new for me and it’s difficult for me to understand how things work, for example i wouldn;t have figured out to use “last_triggered” in it until you said so.
I will try a few more things. My idea was to do a diff against current time. And when it’s negative it would be completed already and postive would mean how long untill finished. Would that be a good approach and is that easy to accomplish?
Also the remaining time is dynamic, not sure if that would give issues?
Thanks for your help and templating example.
I’ll try to find some documentation and examples for command line sensors.
Below is a screenshot that shows completed time and remaining time (highlighted) together. In my situation i’m only intersted in remaining time but i already have that covered once i have the timing thingy fixed.
