Today I changed ISPs. I wanted to run their modem/router in bridge mode and use my current router to run everything. Unfortunately, when the modem/router is put in bridge mode, there is significant degradation in speed. So I opted to use their modem/router as my primary router and use my current router simply for wifi and connected it via a Lan-to-Lan connection. All connections around the house working fine.
My issue is that I can no longer connect to HA remotely while I previously had no issues with my DuckDNS and Nginx setup. I’ve opened port 443 on my new ISP modem/router, restarted HA, etc. Also, there are no errors in the logs. I’m at a loss.
Appreciate any thoughts on how I can get my remote access working again. Thank you.
Note: I can connect locally with a HTTP://192.168.1.XX:8123 address.
