iSponsorBlockTV block YouTube sponsor sections on local Apple TVs
This is the first addon I’ve released and there be dragons.
This addon lets you run iSponsorBlockTV to block YouTube sponsor sections on any connected Apple TV. It must be run on the local network.
Known Issues
  1. You need to run iSponsorBlockTV elsewhere first to authenticate with the Apple TVs. You must then take the generated config and turn it into YAML to use in the addon settings. This only needs to run when you add Apple TVs.
  2. There is currently no connection with the existing Home Assistant Apple TV integration, this addon uses it’s own keys to communicate with the Apple TVs (hence the above step).
I need some major help configuring your add in
It definitely requires installing the main iSponsorBlockTV (not related to Home Assistant) and extracting the config file after configuring it. Just paste it into the edit addon YAML box and it gets converted. It’s nice to have watchdog option just in case and also see the logs after it’s been started.
In the screen id there is number like: 270099966658? in this format? from the “link with tv” screen in youtube “app” settings that is running on the tv?
and the name I can set myself?
I’m trying to do manual config from HA side, without ssh
For me it does not seem to work - or at least ads are not muted (I stopped paying premium because of sponsors and ui on desktop, so I get ads now)
api key is from could.google.com youtube data v3 api?
How do I run setup wizzard thing on normal isponsblocktv running in docker after initial setup?
main.py --setup
:point_right: Installation · dmunozv04/iSponsorBlockTV Wiki (github.com)
Anyone getting this error - “Cant open config.json” when running the setup command described in the Documentation tab ?
rm -rf /tmp/config && mkdir /tmp/config && docker run --rm -it -v /tmp/config:/app/data --net=host ghcr.io/dmunozv04/isponsorblocktv --setup-cli && cat /tmp/config/config.json
this doesn’t seem to update the Configuration tab either.
I installed the add-on v.2.1.2 and faced the following issue:
~ # docker logs -f addon_932a64e5_isponsorblocktv
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun isponsorblocktv (no readiness notification)
s6-rc: info: service legacy-services successfully started
[23:03:34] INFO: Starting...
2025-01-14 23:03:40,050 - iSponsorBlockTV-tufv854ill704gciiae1d5863c - INFO - Starting device
Unclosed client session
client_session: <aiohttp.client.ClientSession object at 0xffff8fea6030>
I use hass.io on Armbian (bookworm)
  • Core 2025.1.2
  • Supervisor 2024.12.3
I tried to run a regular container and it works like a charm.
Anybody faced the issue like so or knows what’s a cause?
Did you ever figure this out? In a similar situation. Tried running in SSH on HA but got an error bash: docker: command not found
This definitely need to be updated, on the repo it’s still version 2.3.0 (2.6.0 is the newest), this probably fix a lot of bugs that could happen
The official release now includes windows binary. Windows steps as follows.
  1. Get iSponsorBlockTV-x86_64-windows from the releases page and add .exe extension Releases · dmunozv04/iSponsorBlockTV
  2. Run iSponsorBlockTV-x86_64-windows.exe --setup and add ‘link with tv’ code’ and google api key
  3. Get the config file (see file path below), paste it into the HAOS addon YAML and hit save. (FYI the JSON gets converted to YAML)
    %LOCALAPPDATA%\dmunozv04\iSponsorBlockTV\config.json or
    %USERPROFILE%\AppData\Local\dmunozv04\iSponsorBlockTV\config.json
Thanks @ha15
