I want to share my first add-on which I’ve created.
Add my repository to the add-on store, check for updates and you can install it.
Try it and any comment is welcome
Пусто. Там нет репозитория.
Empty. There is no repository.
Is it working for you? I get only bashio error when trying to run.
same: exec: fatal: unable to exec bashio : No such file or directory
Any ideas @LJsquare?
I get the same error
s6-rc: info: service s6rc-oneshot-runner: starting s6-rc: info: service s6rc-oneshot-runner successfully started s6-rc: info: service fix-attrs: starting s6-rc: info: service fix-attrs successfully started s6-rc: info: service legacy-cont-init: starting s6-rc: info: service legacy-cont-init successfully started s6-rc: info: service legacy-services: starting s6-rc: info: service legacy-services successfully started exec: fatal: unable to exec bashio : No such file or directory s6-rc: info: service legacy-services: stopping s6-rc: info: service legacy-services successfully stopped s6-rc: info: service legacy-cont-init: stopping s6-rc: info: service legacy-cont-init successfully stopped s6-rc: info: service fix-attrs: stopping s6-rc: info: service fix-attrs successfully stopped s6-rc: info: service s6rc-oneshot-runner: stopping s6-rc: info: service s6rc-oneshot-runner successfully stopped
LJsquareLaurens-Jan Merkx Ist kaputt, funktioniert nicht.
Is broken, does not work.
Sorry for not responding.
I’ve just fix the addon and it should work again.
The new version is now 0.91.
Is possible to add it as iframe and the access it trough home assistant from internet? I added http://addon-ip:8090 and when I am on my wifi is ok, when I try from internet I get error on iframe: Unable to load iframe at website using http: if home assistant is served over https.
