duceduc
October 17, 2024, 12:28am
1
Hello there,
I am trying to add the start_time
for this sensor, but it comes up blank.
- trigger:
- platform: calendar
event: start
entity_id: calendar.appointments
offset: "-24:00:00"
- platform: time
at: '23:59:58' # resets to none
- name: "Appointmenttomorrow"
state: |
{% if 'calendar_event' in trigger and trigger.calendar_event.description|default('none') | lower | regex_search('@doctor|annual') %}
{{ trigger.calendar_event.summary }}
{% else %} none {% endif %}
attributes:
start_time: "{{ trigger.calendar_event.start_time }}" # <-- not working.
filter_key: "tomorrow"
I also tried adding an if statement, but that does not work as well.
{% else %} t {% endif %}
isn’t the trigger var trigger.calendar_event.start
tom_l
October 17, 2024, 1:43am
4
It is. See: https://www.home-assistant.io/docs/automation/templating/#calendar
But it is not available for the second time trigger. That only has these variables: https://www.home-assistant.io/docs/automation/templating/#time
So you cant use trigger.calendar_event.start
when the time trigger occurs. You will need some other way of getting the event start time (t).
{% if trigger.id == 0 and trigger.calendar_event.description|default('none') | lower | regex_search('@doctor|annual') %}
{{ trigger.calendar_event.start }}
Another way of determining which trigger it was: trigger.platform == 'calendar'
need to fix up his “then” clause too:
Hey. Thanks for the replies guys. I tested the code, but it still not showing up. I am assuming `.id == 01 is the 1st trigger?? Should I add an id=name to the trigger instead??
- trigger:
event: start
offset: "-24:00:00"
- platform: time
state: |
attributes:
start_time: |
{% else %} {% endif %}
tom_l
October 17, 2024, 3:51am
8
Correct. Yes that is another option as is this:
Thank you tom. We are almost there. Now I want to only display the appointment time 14:30
. It is adding +09:00:00
to the end and I do know know how to interpret that. I think to get the at, I need something similar to this? It is throwing an error due to the +09:00:00 or is there another way to achieve what I want???
start_time: 2024-10-18T14:30 :00+09:00
filter_key: tomorrow
friendly_name: Appointmenttomorrow
{% set at = state_attr('sensor.appointmenttomorrow', 'start_time') %}
{% set at = as_timestamp(strptime(at,'%Y-%m-%dT%H:%M:%S')) %}
{{ at | timestamp_custom("%H:%M") }}
Error:
ValueError: Template error: strptime got invalid input '' when rendering template '{% set ct = state_attr('sensor.appointmenttomorrow', 'start_time') %} {% set at = as_timestamp(strptime(at,'%Y-%m-%dT%H:%M:%S')) %} {{ ct | timestamp_custom("%H:%M") }}' but no default was specified
duceduc
October 17, 2024, 7:41am
10
ok. I think I got. This will give me the appointment time in 24hr format.
{{ ( as_timestamp(state_attr('sensor.appointmenttomorrow', 'start_time'))) | timestamp_custom('%H:%M') }}
Working:
- trigger:
event: start
offset: "-24:00:00"
- platform: time
state: |
attributes:
start_time: |
{% if trigger.platform == 'calendar' and trigger.calendar_event.description|default('none') | lower | regex_search('@doctor|annual') %}
