Since the Most recent update when I try to alarm my code using the pai (Paradox) configuration I get the following error: “Failed to call service alarm_control_panel/alarm_arm_away. Validation error: Arming requires a code but none was given for alarm_control_panel.evo192_partition_haus”
I dont know where to add the code is in my configuration just like the example
Here is my configuration:
LOGGING_LEVEL_CONSOLE: 20
LOGGING_LEVEL_FILE: 40
CONNECTION_TYPE: IP
SERIAL_PORT: /dev/ttyUSB0
SERIAL_BAUD: 9600
IP_CONNECTION_HOST: ...*
IP_CONNECTION_PORT: 10000
IP_CONNECTION_PASSWORD: paradox
KEEP_ALIVE_INTERVAL: 10
LIMITS:
zone: auto
user: 1-10
door: “”
pgm: 1-5
partition: auto
module: “”
repeater: “”
keypad: “”
key-switch: “”
SYNC_TIME: true
SYNC_TIME_MIN_DRIFT: 120
PASSWORD: “0000”
MQTT_ENABLE: true
MQTT_HOST: core-mosquitto
MQTT_PORT: 1883
MQTT_KEEPALIVE: 60
MQTT_USERNAME: pai
MQTT_PASSWORD: ***********
MQTT_HOMEASSISTANT_AUTODISCOVERY_ENABLE: true
COMMAND_ALIAS:
arm: partition all arm
disarm: partition all disarm
MQTT_COMMAND_ALIAS:
armed_home: arm_stay
armed_night: arm_sleep
armed_away: arm
disarmed: disarm
HOMEASSISTANT_NOTIFICATIONS_EVENT_FILTERS:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:283
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 11:37:45 PM (3 occurrences)
Last logged: 11:41:51 PM
[547700583888] Arming requires a code but none was given for alarm_control_panel.partition_area_1
[547114658560] Arming requires a code but none was given for alarm_control_panel.partition_area_1
I think it might actually be something with the alarm panel card. Funny enough, dissrm works fine.
If you click on the alarm widget so that it lists the buttons vertically and then click the gear cog settings, there is a entry field now called default code.
I entered my pass code into that field and now my arming works again.
Had the same issue 3 days ago as well, now working with kosmikza’s suggestion. That said, haven’t had any updates to PAI in 2 months, so a bit concerned how the behaviour has changed. Maybe related to HA update?
My IP150 module can’t see the internet, so assuming it’s not related to IP150 firmware changes.
Adding the default code does solve the arming problem but it also allows anyone to disarm the system without entering a code. Not desirable in my opinion.
Before I was able to arm without the code but the code was required to disarm.
I just ran into the same issue with Abode running through HomeKit device. It is giving me the same error. Running on MAC or IOS I don’t see anywhere to enter the key code in the web interface? The edit settings has no place for a code.
