Following https://siytek.com/esphome-servo-example/#Configure-ESPHome
i’m having issues controlling a servo from an esp8266, D1 Mini. I have used a servo tester (from the same power source) to control the servo position and works, i think my issue is the esp device is not getting the input from the dashboard? i tried to add a log into the yaml to print the value but not sure if i did that correctly?
my aim is to have a few sensors for some garden automations, the other sensors are working fine and see them output on my dashboard. i can see the device in esphome is online and the servo moves on startup.
esphome:
includes:
- water_level_sensor.h
esp8266:
board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxx"
services:
- service: control_servo
variables:
level: float
then:
- lambda: |-
ESP_LOGD("custom", "Servo Level: %.2f", level);
- servo.write:
level: !lambda 'return level / 100.0;'
- service: control_servo2
variables:
level: float
then:
- lambda: |-
ESP_LOGD("custom", "Servo Level2: %.2f", level);
- servo.write:
ota:
password: "xxx"
wifi:
ssid: "xxx"
password: "xxx"
ap:
ssid: "Garden Fallback Hotspot"
password: "xxx"
captive_portal:
i2c:
sda: GPIO4
scl: GPIO5
scan: true
output:
- platform: esp8266_pwm
pin: GPIO2
frequency: 50 Hz
pin: GPIO14
frequency: 50 Hz
servo:
- id: my_servo
output: pwm_output
#auto_detach_time: 2s
- id: my_servo2
output: pwm_output2
binary_sensor:
- platform: gpio
pin: GPIO13
name: "Soil Moisture 1"
device_class: moisture
filters:
- delayed_on: 5s
- delayed_off: 5s
#- platform: gpio
# pin: GPIO15
# name: "Soil Moisture 2"
# device_class: moisture
# filters:
# - delayed_on: 5s
# - delayed_off: 5s
- platform: wifi_signal
update_interval: 60s
- platform: uptime
- platform: custom
lambda: |-
auto my_sensor = new WaterLevelSensor();
App.register_component(my_sensor);
return {my_sensor};
sensors:
name: "Water Level Sensor"
unit_of_measurement: "%"
#update_interval: 10s
- platform: dht
pin: GPIO12
model: DHT11
temperature:
unit_of_measurement: "°C"
accuracy_decimals: 1
humidity:
- platform: pulse_counter
pin: GPIO15
unit_of_measurement: "L/min"
internal_filter: 10us
# Convert pulses to flow rate in liters per minute
filters:
- lambda: |-
return (x / 2.25) * 60.0;
configuration.yaml:
# Loads default set of integrations. Do not remove.
default_config:
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
http:
use_x_forwarded_for: true
trusted_proxies:
- xxx
- platform: systemmonitor
resources:
- type: disk_use_percent
arg: /config
- type: memory_free
input_number:
servo_control:
initial: 0
min: -100
max: 100
step: 1
mode: slider
servo_control2:
initial: 0
min: -100
max: 100
step: 1
mode: slider
automations.yaml:
automation:
- alias: Write Servo Value to ESP
platform: state
entity_id: input_number.servo_control
- service: esphome.garden_control_servo
data_template:
level: "{{ trigger.to_state.state | int }}"
- alias: Write Servo2 Value to ESP
platform: state
entity_id: input_number.servo_control2
- service: esphome.garden_control_servo2
data_template:
terminal output:
[20:20:23][C][ota:465]: There have been 0 suspected unsuccessful boot attempts.
[20:20:23][I][app:029]: Running through setup()...
[20:20:23][I][i2c.arduino:161]: Performing I2C bus recovery
[20:20:23][C][esp8266_pwm:017]: Setting up ESP8266 PWM Output...
[20:20:23][C][dht:011]: Setting up DHT...
[20:20:23][C][pulse_counter:147]: Setting up pulse counter 'Water Flow'...
[20:20:23][C][wifi:037]: Setting up WiFi...
[20:20:23][D][wifi:384]: Starting scan...
[20:20:23][D][sensor:126]: 'Uptime': Sending state 0.14800 s with 0 decimals of accuracy
[20:20:23][D][sensor:126]: 'Water Level Sensor': Sending state 5.00000 % with 0 decimals of accuracy
[20:20:23][D][dht:048]: Got Temperature=20.0°C Humidity=44.0%
[20:20:23][D][sensor:126]: 'Temperature': Sending state 20.00000 °C with 1 decimals of accuracy
[20:20:23][D][sensor:126]: 'Humidity': Sending state 44.00000 % with 1 decimals of accuracy
[20:20:23][D][servo:050]: Servo reached target
[20:20:28][D][binary_sensor:034]: 'Soil Moisture 1': Sending initial state OFF
[20:20:29][D][wifi:399]: Found networks:
[20:20:29][I][wifi:442]: - 'xxx' (xxx) ▂▄▆█
[20:20:29][D][wifi:444]: Channel: 1
[20:20:29][D][wifi:445]: RSSI: -74 dB
[20:20:29][D][wifi:447]: - 'xxx ▂▄▆█
[20:20:29][I][wifi:255]: WiFi Connecting to 'eir33427672'...
[20:20:30][D][pulse_counter:174]: 'Water Flow': Retrieved counter: 0.00 pulses/min
[20:20:30][D][sensor:126]: 'Water Flow': Sending state 0.00000 L/min with 2 decimals of accuracy
[20:20:31][D][dht:048]: Got Temperature=20.0°C Humidity=44.0%
[20:20:31][D][sensor:126]: 'Temperature': Sending state 20.00000 °C with 1 decimals of accuracy
[20:20:31][D][sensor:126]: 'Humidity': Sending state 44.00000 % with 1 decimals of accuracy
[20:20:31][I][wifi:516]: WiFi Connected!
[20:20:31][C][wifi:360]: Local MAC: xxx
[20:20:31][C][wifi:361]: SSID: 'xxx'
[20:20:31][C][wifi:362]: IP Address: xxx
[20:20:31][C][wifi:363]: BSSID: xxx
[20:20:31][C][wifi:365]: Hostname: 'garden'
[20:20:31][C][wifi:367]: Signal strength: -83 dB ▂▄▆█
[20:20:31][C][wifi:371]: Channel: 1
[20:20:31][C][wifi:372]: Subnet: 255.255.255.0
[20:20:31][C][wifi:373]: Gateway: xxx
[20:20:31][C][wifi:374]: DNS1: xxx
[20:20:31][C][wifi:375]: DNS2: 0.0.0.0
[20:20:31][D][wifi:525]: Disabling AP...
[20:20:31][C][ota:089]: Over-The-Air Updates:
[20:20:31][C][ota:090]: Address: garden.local:8266
[20:20:31][C][ota:093]: Using Password.
[20:20:31][C][api:025]: Setting up Home Assistant API server...
[20:20:31][I][app:062]: setup() finished successfully!
[20:20:31][D][sensor:126]: 'WiFi Signal': Sending state -84.00000 dBm with 0 decimals of accuracy
[20:20:31][I][app:102]: ESPHome version 2022.9.2 compiled on May 28 2023, 20:04:37
[20:20:31][C][wifi:502]: WiFi:
[20:20:31][C][wifi:367]: Signal strength: -86 dB ▂▄▆█
[20:20:31][C][wifi:375]: DNS2: xxx
[20:20:31][C][logger:275]: Logger:
[20:20:31][C][logger:276]: Level: DEBUG
[20:20:31][C][logger:277]: Log Baud Rate: 115200
[20:20:31][C][logger:278]: Hardware UART: UART0
[20:20:31][C][i2c.arduino:038]: I2C Bus:
[20:20:31][C][i2c.arduino:039]: SDA Pin: GPIO4
[20:20:31][C][i2c.arduino:040]: SCL Pin: GPIO5
[20:20:31][C][i2c.arduino:041]: Frequency: 50000 Hz
[20:20:31][C][i2c.arduino:044]: Recovery: bus successfully recovered
[20:20:31][I][i2c.arduino:054]: Results from i2c bus scan:
[20:20:31][I][i2c.arduino:060]: Found i2c device at address 0x77
[20:20:31][C][esp8266_pwm:022]: ESP8266 PWM:
[20:20:31][C][esp8266_pwm:023]: Pin: GPIO2
[20:20:31][C][esp8266_pwm:024]: Frequency: 50.0 Hz
[20:20:31][C][esp8266_pwm:023]: Pin: GPIO14
[20:20:31][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Soil Moisture 1'
[20:20:31][C][gpio.binary_sensor:015]: Device Class: 'moisture'
[20:20:31][C][gpio.binary_sensor:016]: Pin: GPIO13
[20:20:31][C][uptime.sensor:031]: Uptime Sensor 'Uptime'
[20:20:31][C][uptime.sensor:031]: State Class: 'total_increasing'
[20:20:31][C][uptime.sensor:031]: Unit of Measurement: 's'
[20:20:31][C][uptime.sensor:031]: Accuracy Decimals: 0
[20:20:31][C][uptime.sensor:031]: Icon: 'mdi:timer-outline'
[20:20:31][C][servo:013]: Servo:
[20:20:31][C][servo:014]: Idle Level: 7.5%
[20:20:31][C][servo:015]: Min Level: 3.0%
[20:20:31][C][servo:016]: Max Level: 12.0%
[20:20:31][C][servo:017]: auto detach time: 0 ms
[20:20:31][C][servo:018]: run duration: 0 ms
[20:20:31][C][dht:017]: DHT:
[20:20:31][C][dht:018]: Pin: GPIO12
[20:20:31][C][dht:022]: Model: DHT11
[20:20:31][C][dht:027]: Update Interval: 10.0s
[20:20:31][C][dht:029]: Temperature 'Temperature'
[20:20:31][C][dht:029]: Device Class: 'temperature'
[20:20:31][C][dht:029]: State Class: 'measurement'
[20:20:31][C][dht:029]: Unit of Measurement: '°C'
[20:20:31][C][dht:029]: Accuracy Decimals: 1
[20:20:31][C][dht:030]: Humidity 'Humidity'
[20:20:31][C][dht:030]: Device Class: 'humidity'
[20:20:31][C][dht:030]: State Class: 'measurement'
[20:20:31][C][dht:030]: Unit of Measurement: '%'
[20:20:31][C][dht:030]: Accuracy Decimals: 1
[20:20:31][C][pulse_counter:160]: Pulse Counter 'Water Flow'
[20:20:31][C][pulse_counter:160]: State Class: 'measurement'
[20:20:31][C][pulse_counter:160]: Unit of Measurement: 'L/min'
[20:20:31][C][pulse_counter:160]: Accuracy Decimals: 2
[20:20:31][C][pulse_counter:160]: Icon: 'mdi:pulse'
[20:20:31][C][pulse_counter:161]: Pin: GPIO15
[20:20:31][C][pulse_counter:162]: Rising Edge: INCREMENT
[20:20:31][C][pulse_counter:163]: Falling Edge: DISABLE
[20:20:31][C][pulse_counter:164]: Filtering pulses shorter than 10 µs
[20:20:31][C][pulse_counter:165]: Update Interval: 10.0s
[20:20:31][C][captive_portal:088]: Captive Portal:
[20:20:31][C][mdns:094]: mDNS:
[20:20:31][C][mdns:095]: Hostname: garden
[20:20:31][C][api:138]: API Server:
[20:20:31][C][api:139]: Address: garden.local:6053
[20:20:31][C][api:141]: Using noise encryption: YES
[20:20:31][C][wifi_signal.sensor:009]: WiFi Signal 'WiFi Signal'
[20:20:31][C][wifi_signal.sensor:009]: Device Class: 'signal_strength'
[20:20:31][C][wifi_signal.sensor:009]: State Class: 'measurement'
[20:20:32][C][wifi_signal.sensor:009]: Unit of Measurement: 'dBm'
[20:20:32][C][wifi_signal.sensor:009]: Accuracy Decimals: 0
[20:20:34][D][sensor:126]: 'Water Level Sensor': Sending state 5.00000 % with 0 decimals of accuracy
[20:20:37][D][api:102]: Accepted xxx
[20:20:38][D][api.connection:861]: Home Assistant 2023.5.4 (192.168.1.10): Connected successfully
[20:20:40][D][pulse_counter:174]: 'Water Flow': Retrieved counter: 0.00 pulses/min
[20:20:40][D][sensor:126]: 'Water Flow': Sending state 0.00000 L/min with 2 decimals of accuracy
[20:20:41][D][dht:048]: Got Temperature=20.0°C Humidity=44.0%
[20:20:41][D][sensor:126]: 'Temperature': Sending state 20.00000 °C with 1 decimals of accuracy
[20:20:41][D][sensor:126]: 'Humidity': Sending state 44.00000 % with 1 decimals of accuracy
[20:20:49][D][sensor:126]: 'Water Level Sensor': Sending state 5.00000 % with 0 decimals of accuracy
[20:20:50][D][pulse_counter:174]: 'Water Flow': Retrieved counter: 0.00 pulses/min
[20:20:50][D][sensor:126]: 'Water Flow': Sending state 0.00000 L/min with 2 decimals of accuracy
[20:20:51][D][dht:048]: Got Temperature=20.0°C Humidity=44.0%
[20:20:51][D][sensor:126]: 'Temperature': Sending state 20.00000 °C with 1 decimals of accuracy
[20:20:51][D][sensor:126]: 'Humidity': Sending state 44.00000 % with 1 decimals of accuracy
if anyone has any suggestions on what could help me that would be great!
