I’m trying to create an automation from my own blueprint. It is neither working nor showing up in the UI. Any idea what I am doing wrong?
I am using packages. The automation is in a file inside packages folder. I have other automations inside packages there as well.
Thank you.
Matt
homeassistant:
packages: !include_dir_named mesa/packages
# Loads default set of integrations. Do not remove.
default_config:
# Text to speech
tts:
- platform: google_translate
### Automations ###
automation ui-automation: !include automations.yaml
### Scripts ###
script ui-script: !include scripts.yaml
### Scenes ###
scene: !include scenes.yaml
### Groups ###
group: !include_dir_merge_named mesa/groups
### Input Booleans ###
input_boolean: !include mesa/inputs/input_booleans.yaml
## Input Numbers ###
input_number: !include mesa/inputs/input_numbers.yaml
## Input Datetimes ###
input_datetime: !include mesa/inputs/input_datetimes.yaml
blueprint:
name: Mesa Motion-Activated Light
description: Turn a light on based on detected motion, only if it's dark
domain: automation
input:
motion_sensor:
description: This sensor will be synchronized with the light
selector:
entity:
domain: binary_sensor
device_class: motion
target_light:
description: The lights to turn on
selector:
entity:
domain: light
illuminance_sensor:
description: The sensor to read the brightness from
selector:
entity:
domain: sensor
device_class: illuminance
lux:
description: The light will turn on only if the lux in the room is less than this value
default: "{{ states('input_number.lights_on_below_lux') | int }}"
selector:
number:
min: 1
max: 1000
brightness:
description: The brightness to set the lights to
default: "{{ states('input_number.dynamic_light_brightness') | int }}"
selector:
number:
min: 1
max: 100
no_motion_wait:
description: Time in minutes to leave the light on after last motion is detected
default: 5
selector:
number:
min: 5
max: 120
unit_of_measurement: minutes
variables:
motion_sensor: !input motion_sensor
target_light: !input target_light
illuminance_sensor: !input illuminance_sensor
lux: !input lux
brightness: !input brightness
no_motion_wait: !input no_motion_wait
mode: restart
max_exceeded: silent
- platform: state
entity_id: !input motion_sensor
to: "on"
- platform: numeric_state
entity_id: !input illuminance_sensor
below: !input lux
condition:
- condition: numeric_state
below: !input lux
- service: light.turn_on
entity_id: !input target_light
brightness_pct: !input brightness
- alias: "Wait until there is no motion from device"
wait_for_trigger:
- platform: state
to: "off"
- alias: "Wait the number of minutes that has been set"
delay: !input no_motion_wait
- alias: "Turn off the light"
service: light.turn_off
target: !input target_light
By the way, you have a trigger to turn on the light when the illuminance level goes below the input value… That will turn on the light even if no movement is happening or when movement stops after a while. Is this really what you want?
@EdwardTFN thank you kindly for your reply. I Just removed those default values and put integers, but it’s still not working. I appreciate you helping me out. You’re right about the blueprint. I’ll fix that.
my idea was that if you are in the room and the sensor is constantly seeing motion, around sunset time, the lights would start as “OFF” given there was sufficient light. If the motion sensor constantly saw motion and the sun fell below the horizon, you’d want the lights to turn on.
Hence the “low lux” trigger.
I’ve added a condition here to restrict this to only fire when the motion sensor sees motion, but this means it doesn’t necessarily need to cross the boundary from no motion to motion.
Reading the docs for the numeric state trigger, it only fires when the below/above threshold is crossed so I shouldn’t have issues with the automation firing a lot.
Does this make sense? Anything you’d improve?
Thank you again.
Matt
blueprint:
domain: automation
input:
motion_sensor:
selector:
entity:
target_light:
selector:
entity:
domain: light
illuminance_sensor:
selector:
entity:
domain: sensor
lux:
default: 15
selector:
number:
min: 1
max: 1000
brightness:
default: 10
selector:
number:
min: 1
max: 100
no_motion_wait:
default: 5
selector:
number:
min: 5
max: 120
mode: restart
- platform: state
to: "on"
below: !input lux
condition:
below: !input lux
- condition: state
state: "on"
- wait_for_trigger:
- platform: state
to: "off"
- delay: !input no_motion_wait
- service: light.turn_off
