Issue installing Home Assistant on raspberry pi 4 - Never finished preparing
I am trying to setup a new instance of Home Assistant on a raspberry pi 4 4gb but it never finishes preparing Home Assistant
I have flashed hassos_rpi4-64-5.10.img.xz to using balana etcher.
i have it connected to wifi by creating the my-network file and can confirm it has internet access by logging into the console and pinging 8.8.8.8
I have tried this with 2 different raspberry pi 4s and a 32gb & 128gb MicroSD and tried the 32 bit instance with the same results.
I am running pihole on my network but have also tried turning it off for the purpose of setting this up.
any help would be greatly appreciated as i have been trying to set this up for over a week
here is a copy of my logs
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[17:25:36] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[17:25:36] INFO: Starting local supervisor watchdog...
20-12-16 17:25:40 INFO (MainThread) [__main__] Initializing Supervisor setup
20-12-16 17:25:41 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
20-12-16 17:25:41 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
20-12-16 17:25:41 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi4-64
20-12-16 17:25:41 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/aarch64-hassio-supervisor with version 2020.12.7
20-12-16 17:25:41 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
20-12-16 17:25:41 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
20-12-16 17:25:41 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
20-12-16 17:25:41 INFO (MainThread) [__main__] Setting up Supervisor
20-12-16 17:25:41 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
20-12-16 17:25:42 INFO (MainThread) [supervisor.host.info] Updating local host information
20-12-16 17:25:42 INFO (MainThread) [supervisor.host.services] Updating service information
20-12-16 17:25:42 INFO (MainThread) [supervisor.host.network] Updating local network information
20-12-16 17:25:43 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
20-12-16 17:25:44 INFO (MainThread) [supervisor.host] Host information reload completed
20-12-16 17:25:44 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
20-12-16 17:25:44 INFO (MainThread) [supervisor.host.services] Reloading local service hassos-apparmor.service
20-12-16 17:25:44 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/aarch64-hassio-dns versions: ['2020.11.0']
20-12-16 17:25:44 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/aarch64-hassio-dns with version 2020.11.0
20-12-16 17:25:44 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
20-12-16 17:25:45 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS homeassistant/aarch64-hassio-dns with version 2020.11.0 - 172.30.32.3
20-12-16 17:25:45 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
20-12-16 17:25:45 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/aarch64-hassio-audio versions: ['17']
20-12-16 17:25:45 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/aarch64-hassio-audio with version 17
20-12-16 17:25:46 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
20-12-16 17:25:47 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio homeassistant/aarch64-hassio-audio with version 17 - 172.30.32.4
20-12-16 17:25:48 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/aarch64-hassio-cli versions: ['2020.11.1']
20-12-16 17:25:48 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/aarch64-hassio-cli with version 2020.11.1
20-12-16 17:25:48 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
20-12-16 17:25:50 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI homeassistant/aarch64-hassio-cli with version 2020.11.1 - 172.30.32.5
20-12-16 17:25:50 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/aarch64-hassio-observer versions: ['2020.10.1']
20-12-16 17:25:50 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/aarch64-hassio-observer with version 2020.10.1
20-12-16 17:25:50 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
21-02-07 11:52:09 INFO (SyncWorker_0) [supervisor.docker.observer] Starting Observer homeassistant/aarch64-hassio-observer with version 2020.10.1 - 172.30.32.6
21-02-07 11:52:09 INFO (SyncWorker_1) [supervisor.docker.interface] Found homeassistant/aarch64-hassio-multicast versions: ['3']
21-02-07 11:52:09 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/aarch64-hassio-multicast with version 3
21-02-07 11:52:09 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
21-02-07 11:52:11 INFO (SyncWorker_0) [supervisor.docker.multicast] Starting Multicast homeassistant/aarch64-hassio-multicast with version 3 - Host
21-02-07 11:52:11 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-02-07 11:52:11 INFO (MainThread) [supervisor.plugins] dns does not have the latest version 2021.01.0, updating
21-02-07 11:52:11 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/aarch64-hassio-dns:2020.11.0 to homeassistant/aarch64-hassio-dns:2021.01.0
21-02-07 11:52:11 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/aarch64-hassio-dns with tag 2021.01.0.
21-02-07 11:52:45 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/aarch64-hassio-dns:2021.01.0 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.01.0&fromImage=homeassistant%2Faarch64-hassio-dns: Internal Server Error ("error parsing HTTP 408 response body: invalid character '<' looking for beginning of value: "<html><body><h1>408 Request Time-out</h1>\nYour browser didn't send a complete request in time.\n</body></html>\n\n"").
21-02-07 11:52:45 ERROR (MainThread) [supervisor.plugins.dns] CoreDNS update failed
21-02-07 11:52:45 ERROR (MainThread) [supervisor.plugins] Can't update dns to 2021.01.0, the Supervisor healthy could be compromised!
21-02-07 11:52:45 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-02-07 11:52:45 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
21-02-07 11:52:45 INFO (SyncWorker_0) [supervisor.docker.interface] Found homeassistant/raspberrypi4-64-homeassistant versions: ['landingpage']
21-02-07 11:52:45 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/raspberrypi4-64-homeassistant with version landingpage
21-02-07 11:52:45 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
21-02-07 11:52:45 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
21-02-07 11:52:46 INFO (SyncWorker_1) [supervisor.docker.homeassistant] Starting Home Assistant homeassistant/raspberrypi4-64-homeassistant with version landingpage
21-02-07 11:52:47 INFO (MainThread) [supervisor.hassos] Detect HassOS 5.10 / BootSlot A
21-02-07 11:52:47 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
21-02-07 11:52:47 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/core/zwave_js/config.json: Service zwave_js not found @ data['discovery'][0]. Got 'zwave_js'
required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/tor/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/chrony/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/bookstack/config.json: required key not provided @ data['boot']. Got None
required key not provided @ data['startup']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/phpmyadmin/config.json: required key not provided @ data['boot']. Got None
required key not provided @ data['options']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/unifi/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/portainer/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/appdaemon/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/grafana/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/influxdb/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/bitwarden/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/adb/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/sqlite-web/config.json: required key not provided @ data['boot']. Got None
required key not provided @ data['schema']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/zerotier/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/grocy/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/traccar/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/airsonos/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/ftp/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/adguard/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/jupyterlab/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/example/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/vscode/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/zwave2mqtt/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/node-red/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/tasmoadmin/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/zwavejs2mqtt/config.json: Service zwave_js not found @ data['discovery'][0]. Got 'zwave_js'
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/tautulli/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/home-panel/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/nut/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/thelounge/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/motioneye/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/aircast/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/lutron-cert/config.json: required key not provided @ data['options']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/ssh/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/plex/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/glances/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 WARNING (MainThread) [supervisor.store.data] Can't read /data/addons/git/a0d7b954/nginxproxymanager/config.json: required key not provided @ data['boot']. Got None
21-02-07 11:52:51 INFO (MainThread) [supervisor.store] Loading add-ons from store: 29 all - 29 new - 0 remove
21-02-07 11:52:51 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
21-02-07 11:52:51 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
21-02-07 11:52:51 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
21-02-07 11:52:51 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
21-02-07 11:52:51 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
21-02-07 11:52:51 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-02-07 11:52:51 ERROR (MainThread) [supervisor.homeassistant.api] Can't update Home Assistant access token!
21-02-07 11:52:51 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
21-02-07 11:52:51 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-02-07 11:52:51 INFO (MainThread) [__main__] Running Supervisor
21-02-07 11:52:51 INFO (MainThread) [supervisor.hassos] Rauc: A - marked slot kernel.0 as good
21-02-07 11:52:51 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2021.01.7
21-02-07 11:52:51 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/aarch64-hassio-supervisor with tag 2021.01.7.
21-02-07 11:53:24 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install homeassistant/aarch64-hassio-supervisor:2021.01.7 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.01.7&fromImage=homeassistant%2Faarch64-hassio-supervisor: Internal Server Error ("error parsing HTTP 408 response body: invalid character '<' looking for beginning of value: "<html><body><h1>408 Request Time-out</h1>\nYour browser didn't send a complete request in time.\n</body></html>\n\n"").
21-02-07 11:53:24 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor failed!
21-02-07 11:53:24 CRITICAL (MainThread) [supervisor.core] Can't update Supervisor! This will break some Add-ons or affect future version of Home Assistant!
21-02-07 11:53:24 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
21-02-07 11:53:24 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
21-02-07 11:53:24 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
21-02-07 11:53:24 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
21-02-07 11:53:24 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
21-02-07 11:53:25 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
21-02-07 11:53:25 INFO (MainThread) [supervisor.misc.hwmon] Started Supervisor hardware monitor
21-02-07 11:53:25 INFO (MainThread) [supervisor.core] Supervisor is up and running
21-02-07 11:53:25 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
21-02-07 11:53:25 INFO (MainThread) [supervisor.host.info] Updating local host information
21-02-07 11:53:25 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.1
21-02-07 11:53:25 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.1.
21-02-07 11:53:25 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-02-07 11:53:25 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-02-07 11:53:25 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-02-07 11:53:25 INFO (MainThread) [supervisor.host.services] Updating service information
21-02-07 11:53:25 INFO (MainThread) [supervisor.host.network] Updating local network information
21-02-07 11:53:27 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-02-07 11:53:27 INFO (MainThread) [supervisor.host] Host information reload completed
21-02-07 11:53:58 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.2.1&fromImage=homeassistant%2Fraspberrypi4-64-homeassistant: Internal Server Error ("error parsing HTTP 408 response body: invalid character '<' looking for beginning of value: "<html><body><h1>408 Request Time-out</h1>\nYour browser didn't send a complete request in time.\n</body></html>\n\n"").
21-02-07 11:53:58 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-07 11:54:28 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.1
21-02-07 11:54:28 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.1.
21-02-07 11:55:01 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.2.1&fromImage=homeassistant%2Fraspberrypi4-64-homeassistant: Internal Server Error ("error parsing HTTP 408 response body: invalid character '<' looking for beginning of value: "<html><body><h1>408 Request Time-out</h1>\nYour browser didn't send a complete request in time.\n</body></html>\n\n"").
21-02-07 11:55:01 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-07 11:55:31 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.1
21-02-07 11:55:31 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.1.
21-02-07 11:56:05 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.2.1&fromImage=homeassistant%2Fraspberrypi4-64-homeassistant: Internal Server Error ("error parsing HTTP 408 response body: invalid character '<' looking for beginning of value: "<html><body><h1>408 Request Time-out</h1>\nYour browser didn't send a complete request in time.\n</body></html>\n\n"").
21-02-07 11:56:05 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-07 11:56:35 INFO (SyncWorker_3) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.1
21-02-07 11:56:35 INFO (SyncWorker_3) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.1.
21-02-07 11:57:08 ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.2.1&fromImage=homeassistant%2Fraspberrypi4-64-homeassistant: Internal Server Error ("error parsing HTTP 408 response body: invalid character '<' looking for beginning of value: "<html><body><h1>408 Request Time-out</h1>\nYour browser didn't send a complete request in time.\n</body></html>\n\n"").
21-02-07 11:57:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-07 11:57:38 INFO (SyncWorker_3) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.1
21-02-07 11:57:38 INFO (SyncWorker_3) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.1.
21-02-07 11:58:11 ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.2.1&fromImage=homeassistant%2Fraspberrypi4-64-homeassistant: Internal Server Error ("error parsing HTTP 408 response body: invalid character '<' looking for beginning of value: "<html><body><h1>408 Request Time-out</h1>\nYour browser didn't send a complete request in time.\n</body></html>\n\n"").
21-02-07 11:58:11 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-07 11:58:41 INFO (SyncWorker_3) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.1
21-02-07 11:58:41 INFO (SyncWorker_3) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.1.
21-02-07 11:59:14 ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.2.1&fromImage=homeassistant%2Fraspberrypi4-64-homeassistant: Internal Server Error ("error parsing HTTP 408 response body: invalid character '<' looking for beginning of value: "<html><body><h1>408 Request Time-out</h1>\nYour browser didn't send a complete request in time.\n</body></html>\n\n"").
21-02-07 11:59:14 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-07 11:59:44 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.1
21-02-07 11:59:44 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.1.
21-02-07 12:00:17 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.2.1&fromImage=homeassistant%2Fraspberrypi4-64-homeassistant: Internal Server Error ("error parsing HTTP 408 response body: invalid character '<' looking for beginning of value: "<html><body><h1>408 Request Time-out</h1>\nYour browser didn't send a complete request in time.\n</body></html>\n\n"").
21-02-07 12:00:17 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-07 12:00:47 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.1
21-02-07 12:00:47 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.1
21-02-07 12:03:57 INFO (SyncWorker_4) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.1.
21-02-07 12:04:30 ERROR (SyncWorker_4) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.2.1&fromImage=homeassistant%2Fraspberrypi4-64-homeassistant: Internal Server Error ("error parsing HTTP 408 response body: invalid character '<' looking for beginning of value: "<html><body><h1>408 Request Time-out</h1>\nYour browser didn't send a complete request in time.\n</body></html>\n\n"").
21-02-07 12:04:30 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-02-07 12:05:00 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image homeassistant/raspberrypi4-64-homeassistant:landingpage to homeassistant/raspberrypi4-64-homeassistant:2021.2.1
21-02-07 12:05:00 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image homeassistant/raspberrypi4-64-homeassistant with tag 2021.2.1.
21-02-07 12:05:34 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install homeassistant/raspberrypi4-64-homeassistant:2021.2.1 -> 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.2.1&fromImage=homeassistant%2Fraspberrypi4-64-homeassistant: Internal Server Error ("error parsing HTTP 408 response body: invalid character '<' looking for beginning of value: "<html><body><h1>408 Request Time-out</h1>\nYour browser didn't send a complete request in time.\n</body></html>\n\n"").
21-02-07 12:05:34 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
It seems to go wrong from line 55
Can’t install homeassistant/aarch64-hassio-dns:2021.01.0 → 500 Server Error for http+docker://localhost/v1.40/images/create?tag=2021.01.0&fromImage=homeassistant%2Faarch64-hassio-dns
Can you check if your internet connection is setup and docker has connection to WAN and DNS?
dear All
can you give me guidance
I want to install HA by docker container in my RPI 4 ( use ubuntu )
I follow guidance ini home assistant web but found this error
hanif@hanif-desktop:~$ sudo docker run -d
'–name homeassistant
'–privileged
'–restart=unless-stopped
'-e TZ=MY_TIME_ZONE
'-v /PATH_TO_YOUR_CONFIG:/config
'–network=host \
[sudo] password for hanif:
Unable to find image ‘ghcr.io/home-assistant/raspberrypi4-homeassistant:stable’ locally
stable: Pulling from home-assistant/raspberrypi4-homeassistant
e160e00eb35d: Pull complete
d7e6ccf946dd: Pull complete
8958e4c1839f: Pull complete
e02cbe685a2a: Pull complete
e4991494d491: Pull complete
a0091412cf98: Pull complete
Digest: sha256:cf2ee738ad60460918f57ebb1ce4ebf2fa61b4247f6089b11cbcfc030c32a470
Status: Downloaded newer image for ghcr.io/home-assistant/raspberrypi4-homeassistant:stable
5852f30e8f004f6658f72374706f2fa8c5279b08968c8d3cc28a20af23ccf466
docker: Error response from daemon: error while creating mount source path ‘/PATH_TO_YOUR_CONFIG’: mkdir /PATH_TO_YOUR_CONFIG: read-only file system.Dear All
your path seems to be incorrectly setup, so docker did not find it.
Thank you
actually i am blank about Linux terminal language
in ubuntu os folder I can find the docker folder
Home/snap/docker/
than there are 3 folders
/800/
/common/
/current/
so what should I do ?
sudo docker run -d
'–privileged
'-e TZ=MY_TIME_ZONE
'–network=host \
should I run again this command
with correct path
and what is the correct path should I write
sorry , very sorry
That is an example. You need to specify an actual existing directory.
MY_TIME_ZONE - so is that, something like Pacific/Auckand
