For testing purpose i want to try Home Assistant OS Release-6 build 6, the latest for the Rpi0, but i can’t finish the installation.
it seems he downloads the latest version 2022.1 instead of the 2021 that i have downloaded.
if I see in the log of the supervisor I notice the following YELLOW line:
22-02-03 21:50:00 WARNING (MainThread) [supervisor.updater] Board 'rpi0-w' not found in version file. No OS updates.
What can i do before buy a RPi4?
The entire supervisor logs:
[20:47:14] INFO: Starting local supervisor watchdog...
22-02-03 20:47:44 INFO (MainThread) [__main__] Initializing Supervisor setup
22-02-03 20:47:45 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
22-02-03 21:47:45 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: raspberrypi
22-02-03 21:47:46 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/armhf-hassio-supervisor with version 2022.01.1
22-02-03 21:47:47 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
22-02-03 21:47:47 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-02-03 21:47:47 INFO (MainThread) [__main__] Setting up Supervisor
22-02-03 21:47:49 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
22-02-03 21:47:51 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
22-02-03 21:47:51 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os
22-02-03 21:47:52 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1
22-02-03 21:47:52 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1
22-02-03 21:47:52 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
22-02-03 21:47:54 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
22-02-03 21:47:56 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
22-02-03 21:47:56 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
22-02-03 21:47:56 INFO (MainThread) [supervisor.host.info] Updating local host information
22-02-03 21:47:57 INFO (MainThread) [supervisor.host.services] Updating service information
22-02-03 21:47:58 INFO (MainThread) [supervisor.host.network] Updating local network information
22-02-03 21:48:02 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-02-03 21:48:02 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-02-03 21:48:02 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
22-02-03 21:48:03 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armhf-hassio-cli with version 2021.12.0
22-02-03 21:48:03 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
22-02-03 21:48:15 INFO (SyncWorker_1) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/armhf-hassio-cli with version 2021.12.0 - 172.30.32.5
22-02-03 21:48:17 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armhf-hassio-dns with version 2021.06.0
22-02-03 21:48:17 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
22-02-03 21:48:28 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/armhf-hassio-dns with version 2021.06.0 - 172.30.32.3
22-02-03 21:48:28 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-02-03 21:48:30 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armhf-hassio-audio with version 2021.07.0
22-02-03 21:48:30 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
22-02-03 21:48:48 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/armhf-hassio-audio with version 2021.07.0 - 172.30.32.4
22-02-03 21:48:49 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armhf-hassio-observer with version 2021.10.0
22-02-03 21:48:49 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/armhf-hassio-multicast with version 2021.04.0
22-02-03 21:48:50 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
22-02-03 21:49:01 INFO (SyncWorker_1) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/armhf-hassio-multicast with version 2021.04.0 - Host
22-02-03 21:49:01 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-02-03 21:49:02 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
22-02-03 21:49:02 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi-homeassistant with version landingpage
22-02-03 21:49:02 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
22-02-03 21:49:03 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
22-02-03 21:49:03 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning homeassistant application
22-02-03 21:49:14 INFO (SyncWorker_1) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi-homeassistant with version landingpage
22-02-03 21:49:16 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 6.6 / BootSlot A
22-02-03 21:49:40 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
22-02-03 21:49:40 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
22-02-03 21:49:55 INFO (MainThread) [supervisor.store] Loading add-ons from store: 62 all - 62 new - 0 remove
22-02-03 21:49:55 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
22-02-03 21:49:55 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
22-02-03 21:49:55 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
22-02-03 21:49:55 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
22-02-03 21:49:55 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-02-03 21:49:55 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-02-03 21:49:55 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-02-03 21:49:55 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-02-03 21:49:56 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
22-02-03 21:49:56 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-02-03 21:49:56 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-02-03 21:49:56 INFO (MainThread) [__main__] Running Supervisor
22-02-03 21:49:56 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
22-02-03 21:49:56 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
22-02-03 21:49:56 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
22-02-03 21:49:56 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
22-02-03 21:49:57 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
22-02-03 21:49:57 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
22-02-03 21:49:57 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-02-03 21:49:57 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-02-03 21:49:57 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
22-02-03 21:49:57 INFO (MainThread) [supervisor.host.info] Updating local host information
22-02-03 21:49:57 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi-homeassistant:2022.2.0
22-02-03 21:49:57 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi-homeassistant with tag 2022.2.0.
22-02-03 21:49:57 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-02-03 21:49:58 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-02-03 21:49:58 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-02-03 21:49:58 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-02-03 21:49:58 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
22-02-03 21:49:58 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.CORE
22-02-03 21:49:58 ERROR (MainThread) [supervisor.utils] Can't execute check_trust while a task is in progress
22-02-03 21:49:58 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-02-03 21:49:58 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.PLUGIN
22-02-03 21:50:04 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-02-03 21:50:08 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-02-03 21:50:08 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-02-03 21:50:10 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi-homeassistant:2022.2.0: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2022.2.0&fromImage=ghcr.io%2Fhome-assistant%2Fraspberrypi-homeassistant: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: TLS handshake timeout")
22-02-03 21:50:10 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
22-02-03 21:50:15 INFO (MainThread) [supervisor.host.services] Updating service information
22-02-03 21:50:23 INFO (MainThread) [supervisor.host.network] Updating local network information
22-02-03 21:50:23 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-02-03 21:50:23 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-02-03 21:50:23 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
22-02-03 21:50:38 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-02-03 21:50:38 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-02-03 21:50:40 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi-homeassistant:2022.2.0
22-02-03 21:50:40 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi-homeassistant with tag 2022.2.0.
