Greetings.
I am trying to read 100balance BMS data with ESPHome, via RS-485 using my poorly assembled code (poor coder here):
esphome:
friendly_name: 100balancebms
esp32:
board: esp32dev
framework:
type: arduino
logger:
level: DEBUG
api:
encryption:
key: "9m9SELxwXDJiWu1s/Kgs4N12efaD1u5/6v9bKtX5sUs="
ota:
password: "50a122ebadf07ef55ed908b52c7c51b5"
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.1.87
gateway: 192.168.1.1
subnet: 255.255.255.0
ap:
ssid: 100balancebms Fallback Hotspot
password: HMVA5x3DAjDy
captive_portal:
uart:
- id: uart_0
baud_rate: 9600
tx_pin: GPIO17
rx_pin: GPIO16
debug:
direction: BOTH
modbus:
- id: modbus0
uart_id: uart_0
send_wait_time: 1000ms
modbus_controller:
- id: bms
address: 0x81
modbus_id: modbus0
command_throttle: 5000ms
update_interval: 10s
setup_priority: -20
- platform: modbus_controller
modbus_controller_id: bms
address: 0x30
register_type: holding
value_type: U_WORD
unit_of_measurement: C
device_class: temperature
state_class: measurement
accuracy_decimals: 1
filters:
- multiply: 0.001
- offset: -40
And the the log output is as follows:
INFO ESPHome 2024.5.5
INFO Reading configuration /config/100balancebms.yaml...
INFO Starting log output from 192.168.1.87 using esphome API
INFO Successfully connected to 100balancebms @ 192.168.1.87 in 0.115s
INFO Successful handshake with 100balancebms @ 192.168.1.87 in 0.106s
[15:46:58][I][app:100]: ESPHome version 2024.5.5 compiled on Jul 17 2024, 15:45:13
[15:46:58][C][wifi:580]: WiFi:
[15:46:58][C][wifi:408]: Local MAC: FC:E8:C0:7D:BE:58
[15:46:58][C][wifi:413]: SSID: [redacted]
[15:46:58][C][wifi:416]: IP Address: 192.168.1.87
[15:46:58][C][wifi:420]: BSSID: [redacted]
[15:46:58][C][wifi:421]: Hostname: '100balancebms'
[15:46:58][C][wifi:423]: Signal strength: -72 dB ▂▄▆█
[15:46:58][C][wifi:427]: Channel: 1
[15:46:58][C][wifi:428]: Subnet: 255.255.255.0
[15:46:58][C][wifi:429]: Gateway: 192.168.1.1
[15:46:58][C][wifi:430]: DNS1: 0.0.0.0
[15:46:58][C][wifi:431]: DNS2: 0.0.0.0
[15:46:58][C][logger:185]: Logger:
[15:46:58][C][logger:186]: Level: DEBUG
[15:46:58][C][logger:188]: Log Baud Rate: 115200
[15:46:58][C][logger:189]: Hardware UART: UART0
[15:46:58][C][uart.arduino_esp32:137]: UART Bus 1:
[15:46:58][C][uart.arduino_esp32:138]: TX Pin: GPIO17
[15:46:58][C][uart.arduino_esp32:139]: RX Pin: GPIO16
[15:46:58][C][uart.arduino_esp32:141]: RX Buffer Size: 256
[15:46:58][C][uart.arduino_esp32:143]: Baud Rate: 9600 baud
[15:46:58][C][uart.arduino_esp32:144]: Data Bits: 8
[15:46:58][C][uart.arduino_esp32:145]: Parity: NONE
[15:46:58][C][uart.arduino_esp32:146]: Stop bits: 1
[15:46:58][C][modbus:143]: Modbus:
[15:46:58][C][modbus:145]: Send Wait Time: 1000 ms
[15:46:58][C][modbus:146]: CRC Disabled: NO
[15:46:58][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'Temperature 1'
[15:46:58][C][modbus_controller.sensor:010]: modbus_controller.sensor Device Class: 'temperature'
[15:46:58][C][modbus_controller.sensor:010]: modbus_controller.sensor State Class: 'measurement'
[15:46:58][C][modbus_controller.sensor:010]: modbus_controller.sensor Unit of Measurement: 'C'
[15:46:58][C][modbus_controller.sensor:010]: modbus_controller.sensor Accuracy Decimals: 1
[15:46:58][C][captive_portal:088]: Captive Portal:
[15:46:58][C][mdns:115]: mDNS:
[15:46:58][C][mdns:116]: Hostname: 100balancebms
[15:46:58][C][ota:096]: Over-The-Air Updates:
[15:46:58][C][ota:097]: Address: 192.168.1.87:3232
[15:46:58][C][ota:100]: Using Password.
[15:46:58][C][ota:103]: OTA version: 2.
[15:46:58][C][api:139]: API Server:
[15:46:58][C][api:140]: Address: 192.168.1.87:6053
[15:46:58][C][api:142]: Using noise encryption: YES
[15:46:58][C][modbus_controller:298]: ModbusController:
[15:46:58][C][modbus_controller:299]: Address: 0x81
[15:47:00][D][uart_debug:114]: >>> 81:03:00:30:00:01:9B:C5
[15:47:00][W][modbus:135]: Got Modbus frame from unknown address 0x51!
[15:47:00][D][uart_debug:114]: <<< 51:03:02:00:43:39:B9
[15:47:05][W][modbus_controller:136]: Duplicate modbus command found: type=0x3 address=48 count=1
[15:47:05][D][uart_debug:114]: >>> 81:03:00:30:00:01:9B:C5
[15:47:05][W][modbus:135]: Got Modbus frame from unknown address 0x51!
[15:47:05][D][uart_debug:114]: <<< 51:03:02:00:43:39:B9
[15:47:10][D][uart_debug:114]: >>> 81:03:00:30:00:01:9B:C5
[15:47:10][W][modbus:135]: Got Modbus frame from unknown address 0x51!
[15:47:10][D][uart_debug:114]: <<< 51:03:02:00:43:39:B9
[15:47:15][W][modbus_controller:136]: Duplicate modbus command found: type=0x3 address=48 count=1
[15:47:15][D][uart_debug:114]: >>> 81:03:00:30:00:01:9B:C5
[15:47:15][W][modbus:135]: Got Modbus frame from unknown address 0x51!
[15:47:15][D][uart_debug:114]: <<< 51:03:02:00:43:39:B9
In the code I have inserted just one sensor for testing purposes. BMS default adress is 0x81, but the reply is according to the info from the seller from the adress0x51? It seems to recieve some frames from the BMS but with different adress. Does anybody know what else would be necessery to recieve data from the BMS?
I’ve contacted the manufacturer directly for RS-485 addressing and recieved such guidelines:
Will it work with ESPHome modbus component?
Here is a snippet of address table:
and the data type is declared as UNSIGNED SHORT INT. Does this correspond to U_WORD in ESPHome?
Would appriciate any guidelines and tips how to get it to work. I have a solar inverter connected already through RS-485 using syssi’s SMGII configuration from github, and it worked out of the box. I have used this config and modified it to try to connect to the BMS but to no avail apart from recieving random frames.
