Issue: Integration 'config_check' not found
Hi all,
since the upgrade to 22.6.2 from 22.4.2 (I believe) I am seeing the following issue in the log and I am unable to restart home assistant (as config_check appears to be missing).
Any ideas?
Thx in advance
The system cannot restart because the configuration is not valid: Integration error: config_check - Integration ‘config_check’ not found.
5:54:09 PM – (ERROR) Home Assistant Core Integration - message first occurred at 5:49:21 PM and shows up 3 times
config_check is probably the custom_component from Ludeeus, so it seems that you may have removed it, or you just installed it and need to restart HA before adding config_check: to configuration.yaml. Really, the built-in service homeassistant.check_config is fine and you don’t really need that custom component.
Thanks for the swift reply.
Deleted “config_check:” in the configuration.yaml and now everything is fine.
Thx a lot again…
