Hello, first time poster, I am trying to write a script for a sequence to engage the button on my A/C. It is a little tricky since it requires 2 presses, 1 to wake up the control panel, and then 1 more press to actually toggle the A/C on/off.
This is my script:
toggle_ac:
alias: Toggle A/C
description: ""
sequence:
- if:
- condition: template
value_template: >-
{{ (now().timestamp() - state_attr(last_pressed_state, 'timestamp')) > 60 }}
then:
- type: turn_on
device_id: "{{ device_id(switch_bot) }}"
entity_id: "{{ switch_bot }}"
domain: switch
- service: input_datetime.set_datetime
timestamp: "{{ now().timestamp()|round }}"
entity_id: "{{ last_pressed_state }}"
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
- type: turn_on
domain: switch
fields:
last_pressed_state:
name: Last Pressed State
required: true
example: input_datetime.living_room_ac_button_last_pushed
default: input_datetime.living_room_ac_button_last_pushed
selector:
entity:
domain: input_datetime
switch_bot:
required: true
example: switch.bot_40d6
default: switch.bot_40d6
selector:
entity:
integration: switchbot
domain: switch
mode: queued
icon: mdi:air-conditioner
max: 5
I’ve tested this with hardcoded entity IDs and such and it works, but trying to make it into a script where I can repeat this across different A/C units in my house is proving tricky. When I edit this YAML and try to load it into HA, it fails to load and leaves this error in my logs:
Logger: homeassistant.components.script
Source: components/script/config.py:212
Integration: Script (documentation, issues)
First occurred: 8:17:54 AM (11 occurrences)
Last logged: 8:33:42 AM
Script with alias 'Toggle A/C' failed to setup actions and has been disabled: Entity ID {{switch_bot}} is an invalid entity ID for dictionary value @ data['entity_id']. Got None
Script with alias 'Toggle A/C' failed to setup actions and has been disabled: Entity ID {{ switch_bot }} is an invalid entity ID for dictionary value @ data['entity_id']. Got None
My sense as a programmer is telling me that the evaluation of the template is happening when the YAML is loaded by HA, so since the fields have not been selected yet that results in None
values and it causes the validation to fail.
My question in short is: Is there some different way of writing this so HA understands that the templates should be evaluated later?
Any help is appreciated thanks!
