I am new to Home Assistant and I need some help.
This is the situation:
installed Home Assistant on a Raspberry PI4.
installed MQTT Mosquitto and configured
Flashed Sonnof swithch with tasmota and configured the MQTT
Adapt the configuration.yaml
If I set up in sonoff console ‘SetOption19 1’ the device is properly discovered and displayed in HA overview.
If I set up in sonoff console ‘SetOption19 0’ the device is not available anymore.
Setting the switch manually does not work.
Could anybody please help me in this matter?
Thank you!
I found already an issue based on your video.
Switching on/off SetOption9 0 and 1 changes the topic/prefix order in the tasmota device. I corrected that one but still not ok yet.
Do I have to add
broker: core-mosquitto
username: user
password: pass
discovery: true
