I’m trying to run a python script on mosquitto powered by a raspberry pi on mqttcloud.com, when i check the websocket i get the message back so i seems to work. My issue is that when i want to set a switch to trigger an led but it doesn’t do anything.
if someone can help me it will be great!
(sorry for my bad english)
my python code running on mosquito (raspberry pi)
#!/usr/bin/env python
import paho.mqtt.client as mqtt
import RPi.GPIO as GPIO
def on_connect(client, userdata, rc):
#print ("Connected with rc: " + str(rc))
client.subscribe("kwf/demo/led")
def on_message(client, userdata, msg):
#print ("Topic: "+ msg.topic+"\nMessage: "+str(msg.payload))
if "green" in msg.payload:
#print(" Green on!")
GPIO.output(11, True)
else:
#print(" Green off!")
GPIO.output(11, False)
if "yellow" in msg.payload:
#print(" Yellow on!")
GPIO.output(12, True)
else:
#print(" Yellow off!")
GPIO.output(12, False)
if "red" in msg.payload:
#print(" Red on!")
GPIO.output(13, True)
else:
#print(" Red off!")
GPIO.output(13, False)
client = mqtt.Client()
client.on_connect = on_connect
client.on_message = on_message
client.connect("m21.cloudmqtt.com", 17644, 60)
GPIO.setmode(GPIO.BOARD)
GPIO.setup(11, GPIO.OUT)
GPIO.setup(12, GPIO.OUT)
GPIO.setup(13, GPIO.OUT)
client.loop_forever()
Please format your code blocks in your post so they can be read correctly. Highlight your code blocks and press the preformated text button in the post editor as shown below:
Hi gpbenton thank you for anwsering on this issue, i get this after uncomment the print line: !/usr/bin/env python
/home/pi/mqtt_led_client.py: line 1: !/usr/bin/env: No such file or directory
/home/pi/mqtt_led_client.py: line 3: import: command not found
/home/pi/mqtt_led_client.py: line 4: import: command not found
/home/pi/mqtt_led_client.py: line 6: syntax error near unexpected token `('
/home/pi/mqtt_led_client.py: line 6: `def on_connect(client, userdata, rc):'
I think you removed the comment from the first line, as well as the print lines. The comment on the first line is important, so you need to put it back and run the program again.
Good. You connected, which is normally the tricky bit.
Now I think you want to turn the lights on by changing a switch in the HA screen,
If so, you need to change the switch state_topic and command_topic to 'kwf/demo/led`, to match the topic being received.
The ‘payload_on’ needs to be ‘green’ (to switch the green led on) and the ‘payload_off’ needs to be an empty string “” (or anything other than green, yellow or red)
The file is running, so there is no need to change file permissions for the moment. You may need to once we get the message from cloudmqtt, because I don’t know if you need root permission to access the GPIO pins.
Leaving read and write enabled on the broker is fine for now, but you may want to tighten it up once it is working.
At the moment I’m puzzled as to why the broker is not passing on the message, as it obviously has received it, and it looks like the subscription is ok.
I’m not sure where this is coming from. Is something else publishing to this topic from your yaml file?
I have looked more closely at your connect message, and rc: 5 indicates
Connection refused - not authorised
So you have to include a username and password in your python script to connect to mqtt. I haven’t used paho, but looking through the documentation, I think you just need to do
File "/home/pi/mqtt_led_client.py", line 35, in <module>
client.username_pw_set(rsbpi, rspbi)
NameError: name 'rsbpi' is not defined
The username and password are strings and need to be in quotes. The way you have referred to them they are seen as variables, which it can’t find the definition of.
