I recently switched from ZHA to Z2M and now I cannot perform a backup in Home Assistant. It look like it is erroring out on ZHA still being active even though it does not show in the integrations panel. However I still have the “Add Zigbee Device” button for ZHA when clicking “Add Integration”. This will lead to the ZHA config page with the “Network” “Groups” and “Visualization” tabs. The logs show unknown command each time I navigate to the page and there is no data shown in any field.
I am not sure where to look in the files to remove this ghost setup of ZHA. I even added my coordinator back and then deleted it with no change. I have tried searching around but cannot find anything related to the errors I am getting. Does any one know where this could be located in the config files so that I can remove it?
2023-01-24 18:23:31.843 INFO (MainThread) [homeassistant.components.websocket_api.http.connection] [140627865470288] Received unknown command: zha/devices/permit
2023-01-24 18:23:33.096 INFO (MainThread) [homeassistant.components.websocket_api.http.connection] [140627865470288] Received unknown command: zha/configuration
2023-01-24 18:23:33.097 INFO (MainThread) [homeassistant.components.websocket_api.http.connection] [140627865470288] Received unknown command: zha/network/settings
2023-01-24 18:31:40.860 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140394162856352] Error handling message: Unknown error (unknown_error) from 192.168.x.x
File "/usr/lib/python3.10/site-packages/homeassistant/components/websocket_api/decorators.py", line 27, in _handle_async_response
await func(hass, connection, msg)
File "/usr/lib/python3.10/site-packages/homeassistant/components/backup/websocket.py", line 70, in handle_create
backup = await manager.generate_backup()
File "/usr/lib/python3.10/site-packages/homeassistant/components/backup/manager.py", line 172, in generate_backup
raise result
File "/usr/lib/python3.10/site-packages/homeassistant/components/zha/backup.py", line 16, in async_pre_backup
zha_gateway: ZHAGateway = hass.data[DATA_ZHA][DATA_ZHA_GATEWAY]
KeyError: 'zha_gateway'
