I’ve been using hassio OS on a raspberry Pi 3B+ for several month, with my setup opened to the internet thanks to DuckDNS (I followed this amazing tutorial : Beginner’s guide to Home Assistant by JuanMTech )
Following a change of internet service provider (from SFR to Orange, in France), I decided to do a fresh start of my whole setup and reinstalled Hassio from the begining. So I watched the new tutorial from JuanMTech : Link to the video
I did everything as he explains, but ended up stuck when setting up NGINX to use hassio outside of my network. Indeed, I did exactly as he said, but in the end I can only access my configuration with at my local IP address, while connected to my home newtork.
I searched in forums, in the discord and github, but I can’t find any answer to my problem.
Do you guys have any idea of what I could be missing or doing wrong ?
I’m looking into my ISP forum to see if there is a problem with hairpining. Apparently some people have problems with that, but I don’t know if the problem has been fixed.
(I’m in France, the ISP is “Orange”)
So I continued my investigation and tried other solutions without success… But, when I tried to connect to the local IP address of my RaspberyPi (192.168.xxx.xx) on my file explorer (trying things with SambaShare) Google Chrome opened and displayed this message:
Does anyone understand what it means ? I don’t understand what I should do to set up the host.
Thanks for your help ! I hope we can find a solution soon
I had already tried using a different browser, as well as in private mode on a different browser.
Still getting the error “Unable to connect to Home Assistant”.
