Hello there,
I’m a noob, so sorry for not being too technical. I’ve made a mysensor serial gateway using a Arduino Uno and I’m battling to configure it the YAML file. I get the following error when looking at the log file on my mac:
16-07-31 18:29:46 homeassistant.config: Incomplete core config. Auto detected elevation: 1447
16-07-31 18:29:50 mysensors.mysensors: File does not exist or is not readable: /config/mysensors1.pickle
16-07-31 18:29:50 mysensors.mysensors: Trying backup file: /config/mysensors1.pickle.bak
16-07-31 18:29:50 mysensors.mysensors: File does not exist or is not readable: /config/mysensors1.pickle.bak
16-07-31 18:29:50 mysensors.mysensors: Failed to load sensors from file: /config/mysensors1.pickle
16-07-31 18:29:50 mysensors.mysensors: Unable to connect to /dev/cu.usbmodemFA121
16-07-31 18:30:00 mysensors.mysensors: Unable to connect to /dev/cu.usbmodemFA121
16-07-31 18:30:11 mysensors.mysensors: Unable to connect to /dev/cu.usbmodemFA121
16-07-31 18:30:21 mysensors.mysensors: Unable to connect to /dev/cu.usbmodemFA121
16-07-31 18:30:31 mysensors.mysensors: Unable to connect to /dev/cu.usbmodemFA121
16-07-31 18:30:41 mysensors.mysensors: Unable to connect to /dev/cu.usbmodemFA121
16-07-31 18:30:51 mysensors.mysensors: Unable to connect to /dev/cu.usbmodemFA121
Any advice you could offer?
