Issue: Shelly EM added but unusable because "disabled by configuration"
I had to replace a Shelly EM because it was having problems (contacts failure under warranty).
This first EM worked fine with HA. Yesterday I installed the new one but I’m having problems:
  1. I had problems adding it to HA (wasn’t discovered automatically, then other adding to HA issues, finally solved)
  2. Now I can see the new EM in HA, but I cannot use it: the Shelly integration, under this device, reports that I cannot use the device because “it has been disabled by configuration entry” (text could be different, since I’m translating from my language).
I tried to remove then re-add the device, with no luck. I also tried to reboot HA.
It works perfectly into Shelly App.
Also, I’m using 2 current sensors: the first one for the energy coming from the electric meter, the second one just after the home panel main switch, and I noticed a difference of about 25W. Why?
Please help this beginner guy :slight_smile:
Thanks!
Solved managing IP and CoIoT settings.
