Hi There,
Since sonos.join
was deprecated in favor of media_player.join
I’m not able to set correctly the volume of my Sonos group thru the master player. Which should be a base and simple function for managing a group of media players…
I need to set the volume on each device separately which is not efficient and misleading to a potential issue when I dynamically group my device based on my automations.
Below are the steps I used to reproduce the behavior
First, unjoin all devices, I’m going thru this step only in this test scenario to ensure that the master is correctly defined and the group is consistent :
service: media_player.unjoin
data: {}
entity_id:
- media_player.mysonos_master
- media_player.mysonos_device1
- media_player.mysonos_device2
- media_player.mysonos_device3
Then join members, where the master should be specified in target > entity_id
as stated in the instruction in Developer Tools > Services > Media player: Join
All available parameters
This service accepts a target, for example:
entity_id: light.bed_light
Parameter Description Example group_members The players which will be synced with the target player. - media_player.multiroom_player2 - media_player.multiroom_player3
service: media_player.join
entity_id: media_player.mysonos_master
group_members:
Now, I try to set the volume thru the master with volume_set
(at this step all devices volume_level
attribute is 0.03) :
service: media_player.volume_set
volume_level: 0.04
Finally, Developer>States
, by filtering my Sonos devices and get the volume_level attribute:
media_player.mysonos_master > volume_level: 0.04
media_player.mysonos_device1 > volume_level: 0.03
media_player.mysonos_device2 > volume_level: 0.03
media_player.mysonos_device3 > volume_level: 0.03
Never had this issue before, when using the deprecated sonos.join
action
Any help or workaround to set correctly the volume thru the master?
